Diamond Record Cutting Styli!
Post: # 7334Unread post mossboss
Wed Jan 13, 2010 6:28 pm
Hey
All in this forum
Any one who wants on or two or more of the above Please post with your requirements in this thread specifiying your cutting head
I will than compile it for the diamond dude
So the sooner the better
Neumann style first cab of the Rank
Other cutting heads as they are required according to demand
Price around the $100 each (estimated at this stage)
May be lower but I doubted Higher it all depends on numbers per type of cutting head
There will be a USA source as well so local postage no duties customs most likely ex stock
About 3-4 weeks
By the way feedback will be absolutely necessary as we are treading hallowed ground with this
"The Vinyl Truth"
piaptk
Post: # 7337Unread post piaptk
Wed Jan 13, 2010 8:26 pm
If they are good, I'd be up for buying three for a Presto 1-C!
PLEASE PLEASE PLEASE!!!!
Post: # 7350Unread post markrob
Thu Jan 14, 2010 10:58 am
I'd be interested in a short shank style for a Grampian head. However, if they are only to be made available in the long shank version for Presto style heads, I have no problem cutting the shank to lenght. I assume there is no need for heater coil if cutting polycarb. Not that I intend to try, but would these work to cut into metal ala DMM blanks?
Simon
Post: # 7351Unread post Simon
Thu Jan 14, 2010 11:07 am
I think the idea is to have them for both long and short shank.
Happy to learn something new.
KALIA
Post: # 7357Unread post KALIA
Thu Jan 14, 2010 12:48 pm
very good initative.
i will purchace 3 styli for a vinylium sc-99 cutterhead.
it would be nice if it is in any way possible to make it easier to mount the stylus . it is very small now with now wieres.. it is a nevours game every time, but im getting better.
so forexample longer shaft or some wieres, could be made on this new?.
cymbalism
Post: # 7365Unread post cymbalism
Thu Jan 14, 2010 7:40 pm
mark me down for three (3) to fit a grampian type-c. the sooner the better, i have a few jobs i need to complete! :)
all the best!
- tommie 'plan 9' emmi
Diamond Stylli
Post: # 7369Unread post mossboss
Thu Jan 14, 2010 10:22 pm
Hey guys
A point that I think I must make clear Since this is new ground there will be issues with them I am convinced of that
If people are fair with feedback in what problems they are having I am sure the guy that makes them will accomodate them with replacements for free
He is no mug either so he can tell if the thing was abused missused or just bad to start of with
I will talk to him about the following:
I think it is fair that any one buying one or whatever number will also get one extra included to start off with just in case
If it is proved that they do work with no issues than people can pay for the second eventually
Dud ones need to be send back to the point of purchase so we can see what problems they have if any
By the way WE need dimensions and samples of the various shanks
So send in any old ones you may have with your orders or better still now so he can get rolling
"The Vinyl Truth"
piaptk
Re: Diamond Stylli
Post: # 7371Unread post piaptk
Fri Jan 15, 2010 12:48 am
mossboss wrote:Hey guys
Do you need a Presto Shank? I've got a totally toasted ruby. But the thing is so screwed, that you wont be able to get good dimensions off the stone, only the shank.
Shanks
Post: # 7372Unread post mossboss
Fri Jan 15, 2010 12:56 am
Yes please this will be fine It will take a bit of time to gather all the different styles of shanks but once there it will be Ok from than on Any one who has a shank/dud stylus can do as well Look up the address at my website and mark mail Att: Chris Moss
Thanks
"The Vinyl Truth"
aaronmn
Post: # 7495Unread post aaronmn
Sat Jan 23, 2010 11:09 am
I'd be interested in one for a Presto 1-C.
waynelectro
Post: # 7496Unread post waynelectro
Sat Jan 23, 2010 6:16 pm
I'd take three of the 5/8" presto style shank for my fairchild.
Dimond Styli
Post: # 7497Unread post mossboss
Sat Jan 23, 2010 6:23 pm
Hey all
May be it be a good idea to pm you address as well as your requirements please
I need to start sorting out who needs what
Also see what specs we need for what people require
As I have already said we are treading new ground so we need to have specs like size shank length diameter and all that kind of stuff
Thanks guys
By the way
Everything is Progressing well
It is looking very positive at present
"The Vinyl Truth"
bancho
Post: # 7499Unread post bancho
Sun Jan 24, 2010 3:41 pm
for me... like markrob said: short shank style for Grampian head.
I'm looking forward! :)
Diamond
Post: # 7500Unread post mossboss
Sun Jan 24, 2010 8:34 pm
Hey All here
Once again
I DO NOT HAVE THE SPECS FOR ALL OF THE STYLI REQUIRED
Please guys
There is no point in saying I want a short one a long one one for this or one for that
It is like foreign languge to me
I NEED TO HAVE SAMPLES OR SPECIFICATIONS
I really hope that this is clear enough
DONT GET UPSET IF I SAY CAN NOT DO as I do not know what they need to be like
I sincerely hope that this is CLEAR CLEAR CLEAR
So if not all or any of you do not bother with it like sending in old shanks or specs I am afraid it will just be a blatant NO until such time as I get SAMPLES OF WHAT IS REQUIRED
Once again I HOPE this is CLEAR
"The Vinyl Truth"
Address
Post: # 7501Unread post mossboss
Sun Jan 24, 2010 10:10 pm
Hey all
Just click on the web site link under my profile to get the adress or email instead of pm here
Whatever suits you
"The Vinyl Truth"
piaptk
Post: # 7503Unread post piaptk
Mon Jan 25, 2010 12:28 am
I'm having a hard time finding any of the many Presto Styli I've ruined in the last month, but I'll send you one when I break another (should be any day now).
:cry: :cry: :cry: :cry:
emorritt
Post: # 7511Unread post emorritt
Mon Jan 25, 2010 9:51 am
As far as the 'long' and 'short' of it (sorry), there really is no point in making two different lengths. Make long shanks only and if you need short, cut it off. There is no difference in the shanks other than length. I have several machines, both consumer and professional that require both lengths. I never order shorts because in some heads, they're too short - others too long. I just order the long shank and once I know what length works best for which machine, I cut to the appropriate length with wire cutters. Simple.
Simon
Post: # 7512Unread post Simon
Mon Jan 25, 2010 10:15 am
I agree
emorritt wrote:As far as the 'long' and 'short' of it (sorry), there really is no point in making two different lengths. Make long shanks only and if you need short, cut it off. There is no difference in the shanks other than length. I have several machines, both consumer and professional that require both lengths. I never order shorts because in some heads, they're too short - others too long. I just order the long shank and once I know what length works best for which machine, I cut to the appropriate length with wire cutters. Simple.
The Long and The short of it
Post: # 7525Unread post mossboss
Tue Jan 26, 2010 9:53 pm
Ahhh Simon
Another One liner
I Love it
Here are 3 very short ones for you to Ha
"The Vinyl Truth"
kgutzke
Post: # 7962Unread post kgutzke
Sat Feb 20, 2010 10:26 pm
I certainly would love two or three for experimentation on my Westrex 3DII head.
