Audax RH5 stylus?
I.S.D
Audax RH5 stylus?
Post: # 60904Unread post I.S.D
Mon Jun 06, 2022 4:12 pm
Is there anywhere to get a new stylus for an Audax RH5?
emidisc
Re: Audax RH5 stylus?
Post: # 60905Unread post emidisc
Mon Jun 06, 2022 7:48 pm
Perhaps a few dimensions would be useful ie overall length diameter of shank & what material do you intend to cut (or emboss)
I.S.D
Post: # 60908Unread post I.S.D
Tue Jun 07, 2022 3:47 am
I’d like to cut lacquers.
I believe it’s SHORT SHANK 5/8" OVER-ALL STYLUS LENGHT.
EposLab
Post: # 60910Unread post EposLab
Tue Jun 07, 2022 4:13 pm
Yes it a short shank , you may ask Mike Dixon. He'll probably have
http:\\www.eposlab.gr
info@eposlab.gr
apoklis
Post: # 60990Unread post apoklis
Fri Jun 24, 2022 8:52 pm
are you looking to cut or emboss? I haves some short sapphire if you are cutting lacquers. If your embossing on polycarbonate, talk to mike about his cones .They have give me the best results. But before you give up on your styles, try using it to emboss on polycarb sheet . When they start adding squeak or floor noise, I turn them 190 degrees for embossing. Lean 3 to 5 degrees forward, put 35grams of weight as a starting point .Then through a microscope, adjust to 3mil groove. Some claim to get as clean a sound as the cones, or better. any way on the off chance you found some lacquers and wanted to cut them , i have some sapphire .dm me
apoklis
Post: # 60991Unread post apoklis
Fri Jun 24, 2022 9:00 pm
meant 180 degrees sorry
