VinylRecorder Groove speed motor noise through record
David34
Re: VinylRecorder Groove speed motor noise through record
Post: # 45316Unread post David34
Sun Dec 25, 2016 9:01 pm
Hey guys n gals../
The power supply we have rigged up is a CODEGEN 400W ATX 2.03 MODEL: 400X
It has a variety of voltages that you can simply have the wire coming out of the box as, we have it as 12v and the wires straight into the RIAA/EQ
Being indépendant of the groove speed motor means there is no chance of any of that whining come through into the cuts.
I would attach a photo but it's not easy through this forum so PM me and Ill email it to you.
Hope this helps some of you guys out. l.
torykay
Post: # 52526Unread post torykay
Tue Mar 05, 2019 11:01 am
does anyone have a photo of this modification? I yes, please mail it to me.
Thanks
David34
Post: # 52720Unread post David34
Wed Mar 27, 2019 4:33 pm
Sorry mate no, it is all installed now and an absolute pain to open. If you know an electrician then it's a simple fix for them!
blackmoondivision
Post: # 53324Unread post blackmoondivision
Mon Jun 10, 2019 11:58 am
SueDenim wrote:At the risk of repeating myself, could you let me know what current (Amps) your new PSU is rated for please?
i.e. the one which now feeds power to your main unit's iRIAA/EQ circuits.
Thanks in advance ;)
Have you find out the answer?
Thanks
Tomas
David34
Post: # 53333Unread post David34
Tue Jun 11, 2019 4:21 am
please PM me your email addresses and I’ll send a photo..
Can’t do it on here for some reason?!
Discomo
Post: # 53339Unread post Discomo
Wed Jun 12, 2019 1:15 am
David34 wrote:please PM me your email addresses and I’ll send a photo..
There's a button 'upload attachment'. press this. Than a subbox opens. Press 'browse'. Now you can find your file on your computer. Then: press 'add the file'. Press 'Submit'.
See attachment!! :)
Xtrica
Post: # 53702Unread post Xtrica
Mon Jul 22, 2019 8:30 am
there's a small cable that connects the two boards, do you just feed 12v directly in that cable?
David34
Post: # 53710Unread post David34
Mon Jul 22, 2019 4:33 pm
Correct!! Supply the PSU as above!
Whine gone!!
Why did Souri not do this!?
Xtrica
Post: # 53732Unread post Xtrica
Tue Jul 23, 2019 5:43 pm
I did this today, it removed the noise that changes with the speed of the motor but there's still something that sounds like an electrical noise.
PMST
Post: # 53733Unread post PMST
Wed Jul 24, 2019 12:17 am
Can you post a audio sample of the noise?
David34
Post: # 53737Unread post David34
Wed Jul 24, 2019 3:12 am
Try a power filter or a behringer hum destroyer..
Xtrica
Post: # 54070Unread post Xtrica
Tue Sep 10, 2019 6:41 am
After many months of testing and headaches I've finally fixed all noises of the vr.
My recommendations in order
Split the power supply of the main unit ( check this thread for how to, although stressful it's quite a cheap and easy fix)
Replace all of souri's RCA cables, keeping lengths as short as possible.
Do not rack all the gear together (unless each rack is isolated from each other, if you don't understand it just keep them stacked and avoid problems)
Remove all lights from the the same power of the machine
Check all digital devices connected to the system for noise (oscilloscope is your friend)
Finally enjoy noiseless cuts!!!
Vinylfan
Post: # 54166Unread post Vinylfan
Mon Sep 23, 2019 7:57 am
Going back to the original post where the question was, why there is a noise coming from the groove speed motor and if this noise might be due to a «earth loop»:
Yes, this noise is due to a ground loop, mostly between the cutter amp and the main unit.
There are 3 ways to solve this:
1. Split the power supply of the main unit as discussed in this thread
2. Use exclusively (and only) the power accessories that came with the VR
3. Disconnect the Ground Pin of the 12V Power supply of the main unit.
Be aware that the 3rd solution might be dangerous in case of an electrical malfunction.
Discomo
Post: # 55734Unread post Discomo
Mon May 18, 2020 1:03 am
This is a very interesting topic and the idea to split the psu to two separate psu’s is marvelous!
But I do wonder how this relates to warranty of the VR. Does anyone know if this mod is agreed upon by Souri?
