Picture Disc UV printing
Sillas
Post: # 64693Post Sillas
Tue Apr 23, 2024 10:48 am
Hi fellow cutters!
Can someone give some details about picture disc UV printing? Like which printer should be used, which blanks to use etc.
Any advice is much appreciated!
South in Cuts
Re: Picture Disc UV printing
Post: # 64694Post South in Cuts
Tue Apr 23, 2024 11:03 am
I would also like to know how to do it or have tips. For example, I have black PETG discs but 0.75mm. If I just glued two sheets together it would be excellent. But how to glue these sheets together. Some talk about spray glue but we don't have much detailed information on how to do it.
boryo
Post: # 64695Post boryo
Tue Apr 23, 2024 11:30 am
you can use double sided sticky foil (not sure about the exact name), no need for spray. the rest is experiments to find your workflow.
i was searching for uv printers some time ago but they were very very expensive for me, even the ones from aliexpress but from what i've learn they are used to print on any material so probably no need to change the blanks.
South in Cuts
Post: # 64697Post South in Cuts
Tue Apr 23, 2024 12:39 pm
Cool Boryo. Thanks for the tip. I'll see if I can find this double sided sticky foil and test it.
boryo
Post: # 64698Post boryo
Tue Apr 23, 2024 12:48 pm
you also need strong laminator to put out bubbles, but for the tests you can do without
South in Cuts
Post: # 64700Post South in Cuts
Tue Apr 23, 2024 1:21 pm
Thanks bro!! 8) 8)
