HAECO & Westrex Cutting Stylus.
Maistrow
Post: # 64574Post Maistrow
Wed Apr 10, 2024 11:47 pm
Hello Trolls,
Just curious if anyone using the Micro - Point WSH-2S cutting stylus in their HAECO SC2 or Westrex 3D2 cutter head is having an issue. It seems that the aluminum shaft with the stylus mounted in it is too long when placing it into the torque tube. This is the WHS-2S-AL cutting stylus. With the stylus is placed in the cutter head, and then you drop the head on to the lacquer and the stylus is on the disk, it seems that you can't get the advance ball to touch the lacquer surface. Perhaps the cutting stylus from Micro Point is out of spec? I never had any problems when using the Transco stylus in the past. Any ideas would be appreciated.
Thanks,
Maistrow
rcvinyl
Re: HAECO & Westrex Cutting Stylus.
Post: # 64576Post rcvinyl
Thu Apr 11, 2024 10:14 am
receive a new stylus today and cut without any problem. do you compare the length of the shank with the previous one?
Maistrow
Post: # 64582Post Maistrow
Sat Apr 13, 2024 6:35 pm
Yes, the Micro Point stylus is a few millimeters longer then the Transco 350 stylus that I was using.
Thanks,
Maistrow
