Groove jumping on VMS70
tjarkpär
Post: # 62167Unread post tjarkpär
Wed Jan 18, 2023 2:23 pm
Hi all,
our VMS70 does some weird jumping/skipping on random places all over the acetate. Most of the grooves are completely fine but every now and then it does overcut 1-2 grooves, as in the picture at around 5 on the scale.
We have a pitch13 driving the leadscrew and using some a tad old mdc acetates. Already oiled the shaft and leadscrew, checked the motor and belt of the pitch13, as well as the depth and alignment of the needle and cutterhead.
Does anyone have an idea what could cause such an issue and how to fix it?
Appreciate every hint
SueDenim
Re: Groove jumping on VMS70
Post: # 62168Unread post SueDenim
Wed Jan 18, 2023 2:50 pm
It looks more like the cut depth is going shallow for 4 rotations, rather than overcutting.
I'm no expert on the VMS70, but you might want to inspect the feedscrew for debris in the thread and also check the halfnut is adjusted correctly too.
andybee
Post: # 62171Unread post andybee
Thu Jan 19, 2023 2:06 am
seems halfnut is jumping, can have several reasons, dirt, loose pin, weak spring...
tjarkpär
Post: # 62173Unread post tjarkpär
Thu Jan 19, 2023 11:07 am
thanks, that did the trick
SueDenim
Post: # 62174Unread post SueDenim
Thu Jan 19, 2023 1:35 pm
Excellent!
Post: # 62188Unread post Aussie0zborn
Sun Jan 22, 2023 12:40 am
You must NOT oil the leadscrew. See the VMS70 instruction manual.
tjarkpär
Post: # 62191Unread post tjarkpär
Mon Jan 23, 2023 7:47 am
okay after checking the bearing it went away for some time, but the dragging is now back - what is the best way to access the halfnut on the leadscrew?
misjah
Post: # 62192Unread post misjah
Mon Jan 23, 2023 9:47 am
Open the cover, remove metal clip and unscrew the nut under the lever then you can pull it out. You need to clean the halfnut every now and then and clean leadscrew
tjarkpär
Post: # 62195Unread post tjarkpär
Mon Jan 23, 2023 3:21 pm
thank you - i got it out and it looks a bit drenched from what i can tell
does anyone sell replacement halfnuts? pref. UK/EU?
boogievan
Post: # 62200Unread post boogievan
Tue Jan 24, 2023 1:05 am
Wonder if Opcode still has some of his clones from 2009. https://deepgroovesmastering.com/.
Post: # 62201Unread post Aussie0zborn
Tue Jan 24, 2023 5:09 am
Don't forget to clean the rotating leadscrew with a wooden toothpick to remove any debris.
tjarkpär
Post: # 62242Unread post tjarkpär
Tue Jan 31, 2023 6:28 pm
Thanks everybody, halfnut is changed, feedscrew is properly cleaned and everything is up and running again - better than ever before.
Mavis
Post: # 63918Unread post Mavis
Sat Jan 06, 2024 9:49 am
We have a similar probelm, where did you find the new halfnut?
leemichael
Post: # 63928Unread post leemichael
Mon Jan 08, 2024 5:53 pm
Surprised that worked at all! There’s nothing left!
