Preparing Pre-Masters for cutting..
Hello brothers and sisters!
Many tests by my side, just to find a solution for cutting without big changes comparing with the original audio source.
Many problem everytime with middle frequences, a lot of distortion on human vocals or on middle range instruments (like guitar)
What's your conclusion?
Re: Preparing Pre-Masters for cutting..
How long is a piece of string??
How about letting us know.....
Which cutting system? Cutterhead? Source Files? Blank Discs?
here we are:
Lathe cut machine: T560
Myshank or vinylrecorder blanks
I drive the music from my laptop.
- concretecowboy71
You may be overloading the head and causing it to resonate. Use EQ to get rid of the problem. Lower the level until the problem goes away. Then raise level until it comes back and use the EQ to tame the bad frequencies and raise the level a bit.
