Polishing and repair of the stylus, the new project
alexsation
Post: # 42266Unread post alexsation
Mon May 02, 2016 4:13 pm
Everyone knows that I sell old Soviet stylus, as it turns out they were of very poor quality because they are meant for cutting ray film. Many of you made sure in low quality and I want to try to give them a second life. I'm going to to try to to sharpen the tip to 2-3 microns, I have the equipment for work with precious stones, and all the necessary appliances. I recently finished a short course of study and some skills to work with precious stones I received.
This is equipment that is available for me.
Best regards, Alexey Sobolev.
http://www.vinylium.ru
http://shop.vinylium.ru
alexsation
Re: Polishing and repair of the stylus, the new project
Post: # 42267Unread post alexsation
Mon May 02, 2016 4:16 pm
alexsation
Post: # 42268Unread post alexsation
Mon May 02, 2016 4:52 pm
The problem is that I do not have the cutting heads a working, but I have ,not working cutting head with the help of which I can check silence of the cut groove. Today I was able to do a test on a black PVC myshank. The first incision was very quiet as diamond, but the second and the third had a hiss and crackle.
Below you see links to several test.
https://youtu.be/pvEtAf2z72E
https://youtu.be/xR6YTFMrPCs
For any help and advice will be very grateful!!
In the coming days I will try sharpen a few stylus and start experimenting with angles and sharpening. All videos of tests I will publish
studiorp
Post: # 42269Unread post studiorp
Mon May 02, 2016 6:09 pm
Why your cutting head isn't working ? You had a Sc-99 once ?
studiorp
Post: # 42270Unread post studiorp
Mon May 02, 2016 6:15 pm
Perhaps this could help :
studiorp
Post: # 42271Unread post studiorp
Mon May 02, 2016 6:17 pm
Before to cut, do you use a sort of antistatic solution to apply on surface disc ? This help reduce the hiss...
EpicenterBryan
Post: # 42272Unread post EpicenterBryan
Mon May 02, 2016 8:04 pm
This information might help.
Micro-Point_StyliBrochure-1.pdf
Bryan
The Shank
Post: # 42276Unread post The Shank
Tue May 03, 2016 2:13 am
alexsation wrote:The first incision was very quiet as diamond
With diamonds, there absolutely no noise, I haven't seen that result on the both video. the test #1 is noisy too.
You won't have good results on plastic with sapphire/rubin.
How do you check the tips and edges after grinding, what kind of microscope?
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
alexsation
Post: # 42277Unread post alexsation
Tue May 03, 2016 4:27 am
studiorp wrote:Why your cutting head isn't working ? You had a Sc-99 once ?
With cutting head Sc-99 is all right))) I took it that would establish a mono head, because stylus in the Sc-99 is not insert)
studiorp
Post: # 42278Unread post studiorp
Tue May 03, 2016 4:33 am
Ah yes, it's true...
alexsation
Post: # 42279Unread post alexsation
Tue May 03, 2016 5:08 am
Steven, I have two microscopes 280 and 360 times. I ordered several measuring USB microscopes with different magnification of 200, 400, 500, 800 and 1000 times. Maybe I did not succeed, but it's worth it!)) The test made not acute stylus, if my memory does not fail, the radius of tip 15 microns. If we remove burnishing facet and make radius 3 micron , the stylus will receive a diamond shape. I do not see reasons for the failure !?
What are the main reasons why Ruby does not give the same quiet groove like a diamond if I repeat a diamond shape?
alexsation
Post: # 42280Unread post alexsation
Tue May 03, 2016 5:11 am
EpicenterBryan wrote:This information might help.
Bryan
Thanks Bryan!
This is very useful information, I will very thorough examine all !!))
sakuszi
Post: # 42289Unread post sakuszi
Tue May 03, 2016 5:05 pm
Plastic pcf etc. is a bad material, corundum [sapphire, ruby] oxides are too soft, but possibly a diamond, but the effect will be poor, big noise, there's nothing you can do about it, who says otherwise let them do the recording on you tube and prove that it will be great ...
Only lacquer master will cut right through your knives with ruby, sapphire, any other material or plate covered with wax, paraffin industrial
I checked it , all badly, damage the knife and the time ...
sakuszi
Post: # 42290Unread post sakuszi
Tue May 03, 2016 5:26 pm
First photo of corundum, sapphire, ruby molecular structure
Second photo molecular structure of the diamond
Plastic thirds photo enlarged microscopic structure is not consistent
relax, plastic is very bad material for cutting :!:
it can only press in,
studiorp
Post: # 42291Unread post studiorp
Tue May 03, 2016 5:40 pm
When you say "plastic", you mean too policarbonate , or only pvc ?
sakuszi
Post: # 42292Unread post sakuszi
Tue May 03, 2016 5:48 pm
studiorp wrote:When you say "plastic", you mean too policarbonate , or only pvc ?
polycarbonate, PVC etc.
Only nitro lacquer has a coherent structure
Please do the actual recording of a knife with a ruby on the board 12 inches pcv and embed real movie on you tube for 20 minutes, wants to see and hear ....
The Shank
Post: # 42300Unread post The Shank
Wed May 04, 2016 1:52 am
sakuszi wrote:Plastic pcf etc. is a bad material, corundum [sapphire, ruby] oxides are too soft, but possibly a diamond, but the effect will be poor, big noise, there's nothing you can do about it, who says otherwise let them do the recording on you tube and prove that it will be great ...
Hey, you just say things you don't know dude... And you assume things you definitely don't know... And it's not the first time.
I think you have definitely no experience or with diamond or with plastic.
I can find here more people than you think using plastic and diamond with perfect unmodulated groove, no background noise... And you are just saying the opposite.
please.... stop.
* Blank records
* Cutting lathe
alexsation
Post: # 42301Unread post alexsation
Wed May 04, 2016 3:10 am
Polycarbonate a very hard material, even a diamond can easily break. At the moment, I am doing the slope on PVC Steven myshank, and also very good for cutting the PET material.
alexsation
Post: # 42302Unread post alexsation
Wed May 04, 2016 3:20 am
Steven, you are a great professional in his work, and to argue with you, I have no right.
The fact is that I got already perfect quiet groove, have long to experiment, not everyone wants to spend as much time to configure the desired angle and spoil the material for testing and tuning. In any case, I will go ahead and try to to get some results.
The Shank
Post: # 42303Unread post The Shank
Wed May 04, 2016 3:34 am
yes sure, go ahead, let us know
* Blank records
* Cutting lathe
