HOW TO MAKE YOUR OWN LACQUER BLANK DISCS
blacknwhite
Post: # 2888Post blacknwhite
Thu Jun 05, 2008 5:07 pm
Grooveguy's recent post made me think to go ahead and write this up and post it.
WHY I'M WRITING THIS: I was going to make laquer blanks myself using my research so far, which I've provided, below. But I just have too many irons in the fire. So, I hope other hobbyists can take what I've found so far, run with it, and supply everyone with alternate sources of laquer blanks.
IDEAL RESULT: It would be nice if different hobbyists with varying degrees of sophisticated home workshop equipment, would start making & providing varying degrees of quality of laquer recording blanks. From the best-possible-quality-at-home kind of thing with arc-welder-cut 1/16" thick circular aluminum metal disc bases and fairly even finishes, down to thick solid 1/10"-thick chipboard/cardboard-based discs with less perfect surfaces (but still a thick even coat, though it may be bumpy), and everything in between, for different price ranges, for different applications.
DISCLAIMER: "I am not TELLING you to do this. Nitrocellulose laquer is highly flammable if not handled wisely, so follow all warnings on the can." I.e. Work with AMPLE VENTILATION, don't leave the can in the hot sun to explode, don't leave windows closed in your 3rd bedroom while lots of blanks are drying so that when you enter & flip on the light switch the spark makes the room explode, etc. DO NOT TRY THIS IF YOU ARE ACCIDENT-PRONE.
WHAT YOU WILL NEED:
- good judgement
- Workspace w/ AMPLE VENTILATION
- "Behlen Nitrocellulose Stringed Instrument Lacquer", from online store called Stewart-Macdonald: (I already researched it via Google Newsgroups - hardcore guitar hobbyists online report good experiences with both this store, and with this product, for producing the finest, mirror-smooth nitrocellulose laquer finish with a bit of flexibility in it)
http://www.stewmac.com/shop/Finishing_supplies/Finishes_and_solvents/Stringed_Instrument_Lacquer.html
- "ColorTone Liquid Pigment for Laquer - Black" (Why? If either plain straight transparent laquer, or lighter-colored laquer, is used to coat the disc, you would not get the high reflectivity of a black-colored laquer. High reflectivity is necessary for easy identification of which parts of a disc have grooves or not, and for visually seeing how smooth or bumpy (quality-grading) the surface is, and how complete the coverage of the disc is.)
http://www.stewmac.com/shop/Finishing_supplies/Colors,_tints,_and_stains/ColorTone_Liquid_Pigments_for_Lacquer.html
- Pure, all-natural Castor Oil, available from online store MotherNature.com: (People online in newsgroups report good experiences ordering from this store. Castor oil is used as a "plasticizer", and is necessary to make the final laquer surface soft enough to cut when the surface dries. This is what was traditionally used in 1930s-40s home & professional laquer recording blanks, according to an article from the ARSC journal detailing chemical composition & restoration techniques for those discs)
http://www.mothernature.com/shop/detail.cfm/sku/85602/S/122406
- Some kind of core material for the blank discs: Use your imagination here. This depends on how good of a workshop you have, and what tools. If you have an arc welder/cutter & have metalworking skills, you can find online or locally & order 1/16" aluminum stock, cut it first down to 12" squares, then punch holes in the centers, make a jig to spin them on the hole & hold the cutting torch a fixed distance, and cut them to near-perfect circles of chosen diameter. At the other end, if all you have is heavy-duty scissors or garden shears, you can order the thick 1/10" (non-corrugated) kind of pressed cardboard stuff they make kiddie "board books" from, the ones where the pages are super-thick cardboard, from places like this online, by doing a Google search for "chipboard":
http://www.dickblick.com/zz131/15/
You could also experiment using the smoother side of 1/8" or 1/4" brown "hardboard" from your local hardware superstore (the stuff they make clipboards out of), or if you feel really gutsy, try using sheets of smooth clear plastic from the same type stores. I assume the plastic would probably be chemically burned & melt from the caustic laquer and result in a toxic puddle of fuming goo, so wouldn't advise it, but it could provide a much cheaper, smoother, and easily cuttable blank material than hardboard or plate metal.
- At least one High-grade professional laquer mastering blank: This is the most expensive part, but would be necessary for reference comparison & tests, to see how good or bad your home-made blanks are: Apollo/Transco's cheapest seems to be their 7-inch blanks, min order of 5 for about $60: As soon as someone continues this research and reports the best ratios for mixing ingredients, this step will no longer be quite as necessary:
http://www.apollomasters.com/products.html#7s
DIRECTIONS:
STEP 1:
Find out the one major missing piece of information in the puzzle: What the proper mixing ration of laquer vs. caster oil should be to produce a recording surface of the same consistency of the industry standard (i.e. an Apollo disc, thus the need for purchasing an Apollo disc for reference). Like I said, I wanted to do this & publish findings, but time won't allow. I've asked professional "acetate" laquer disc collectors and preservationists, and they all tell me, "It was pretty much a secret mixing ratio, and was different for all companies, for example the company AudioDisc which was big in the 1950s and 60s had softer discs than other brands, from using more caster oil". SO, mix up small amounts in small metal or glass containers (i.e. metal spaghetti-sauce-jar lids) of different ratios. Whether to mix by volume or by weight, doesn't make a difference, as long as you're CONSISTENT in your note-taking on your experiments. Then, put thick globs of each mixture at different places on an experimental metal surface, let it dry. When dry, prod the spots with a fingernail, comparing them to the Apollo master, to see which has the most similar softness: Please let the group know your results:
TRIAL 1: 25% castor oil, 75% laquer
TRIAL 2: 10% castor oil, 90% laquer
TRIAL 3: 3% castor oil, 97% laquer
TRIAL 4: 100% laquer
STEP 2:
Come up with some way of coating. Instructions on the laquer can may suggest spraying; this may work for wood finishes but seems it could introduce air bubbles, I don't know. Other ideas:
2.1. Build yourself a rig with a supply jug above a faucet, which would pour into a metal or glass pan which is held at an angle (adjustable for perfect evenness), to "sheet coat" the blanks on a motorized (or *very* *steadily* hand-pulled by someone else??) conveyer pathway, like Apollo/Transco does:
2.2. Dipping: Just have a large round shallow dish with the laquer, like the large round aluminum "drip pans" that go under water heaters, sold at hardware superstores. Wearing proper protective gloves of course, dip the blank discs & hang them to dry (flat, not vertical, which would allow it to run off) somehow, as evenly as possible.
2.3. Do it the way I'm guessing the makers of 1930s-40s home recording blanks did it: Rotational dipping:
Affix the core disc to be coated to a SLOWLY ROTATING (i.e. about 16 rpm or so) motor shaft. Have a tall narrow vertical metal or glass container with the laquer mixtire, and vertically dip the rotating disc into the mixture. The disc is now coated on BOTH sides, so the best way to dry would be to allow it to rotate while drying vertically, to prevent the material from running off the disc, because it's constantly rotating. I've seen an old (1940s?) patent for an idea of a large-scale conveyor belt contraption for making laquer blanks like this. I think this is how the old home blanks were made, since they aren't coated with laquer at the center, under the paper label. If you can't dry it on the rotating motor, you could try homehow hanging it flat to dry, but the laquer on the underside may form droplets all over the surface of the disc as it tries to fall off, and result in a very bumpy underside surface, not sure. Maybe you just wouldn't use the underside. Transco seems to get around this by only coating one side, the TOP, of a disc at a time, as mentioned above in step 2.1. (If they even bother with coating the reverse side at all... Personally haven't ordered directly from them before, just a hobbyist.)
STEP 3.
THICKNESS OF COAT: This could be achieved different ways, if the above single-coat procedure isn't thick enough: (Thickness is vital. If not thick enough, the cutting stylus will go through it to the core and be ruined. Stylii are EXPENSIVE; this will make lots of people very mad at you. Must ensure your coat is atleast as thick as some good reference, for instance, an Apollo/Transco reference master disc.)
3.1. Multiple dippings. time consuming.
3.2. Alternate idea: Allowing the laquer mixture to thicken before applying. This is, I think, what Apollo-Transco does, from looking at their YouTube video: their mix looks quite thick. REMEMBER, the vapors are explosive, so allow it to thicken outdoors. I had in mind building some kind of rig specifically for the purpose, that would use a round
shallow metal pan and a "stirring wedge" which goes the diameter of the pan, affixed to a very slowly rotating (five RPM?) motor (with a friction clutch or pulley, so the mixture doesn't thicken enough to halt & burn out the motor). MUST BE CAREFUL to isolate the motor from the flammable vapors, since of course motors spark. Motors of all kinds, powers, and speeds can easily be found for relatively cheap at this place which I've often ordered from for misc projects, SURPLUS CENTER, http://www.surpluscenter.com/
Imagined possible setup, as viewed from outside the drying box:
As viewed from inside the drying box: there should be an "almost air-tight" seal around the motor shaft as it enters the box:
This might be an overkill, I don't know, I'm paranoid about flammable vapor explosions... note the blower to speed up the removal of the laquer fumes (& therefore speed up the thickening). Also note, that the blower motor IS FORCING AIR *IN* AT THE BEGINNING, NOT PULLING IT *OUT* AT THE END! If you pull it out at the end, you're passing concentrated flammable vapors through a sparking fan motor... BAD. Also note, the long airflow piping, which I would gess (??) should be atleast 10 feet from one end to the other, to prevent the flammable vapors from wrapping around back to the entrance blower motor in too higly concentrated form. Also, I am not reccomending this at all, this is just a crazy idea; Don't do this anywhere near any kids; don't asphixiate someone's pet or kill your grass at the fume exit pipe; so use good judgement and don't harm anyone/anything.
You would have to experiment to figure out how long and at what force of airflow the laquer takes to try to the right consistency to provide the corect coating thickness with the disc-coating method of your choice. Also, you need to remember the weather will make a difference (temp & humidity) and may even prevent it from thickening at all in certain conditions; for details on that, read the laquer can.
You also will need a consistent means of measuring viscosity (thickness) of the laquer, so you can take proper notes on required thickening times at certain temperatures and humidity levels in your area. You can find tools on the web for measuring viscosity of liquids. Or, simply measure the seconds it takes for a certain small measured amount, like 1/2 teaspoon, to run a certain distance, say 5 inches, down a 45-degree-angle smooth surface. You need to have a way of assigning some ballpark consistent measurement number to indicate different thicknesses of mix.
Then, you need to try coating discs using mixtures of different thicknesses, numbering the discs, and keeping a record of which of your experimental discs you coated with which thickness of mixture. Then when the discs dry, find the one with the best thickness. Remember, since this kind of home-brew thickening process probably will result in some lumps in your mixture as it thickens unevenly, you may or may not want to improve quality by filtering it through a wire mesh before coating the discs. And you probably should make your coating a bit thicker than a pro disc, maybe twice as thick, to allow for unevenness & imperfections in coating, which may make certain patches thinner - remember, utmost important rule after safety, not to have thin patches that will kill someone's expensive stylus. Especially if using highly abrasive cheaper base materials like chipboard or hardboard.
If anyone actually tries this, remember it's all just a crazy idea which I've never tried, and which I do not advocate you trying. If you do it anyway, Be safe & be honest, and try it at first on a SMALL SCALE; otherwise, consider carefully the huge mess you may be getting yourself into, & whether you feel up to it without breaking environmental codes, releasing large amounts of dangerous fumes in your neighborhood, etc.
If done on a small enough scale, seems it should be fun & not have fumes above the normal amount for, say, a weekend project of refinishing a deck or a piece of furniture.
If you have great success on small scale, rent a warehouse in a local industrial zone, crank out lots of blanks of varying quality grades for varying prices including cheap "hobbyist-grade", and you'll be everyone's hero!
- Bob
cuttercollector
re: HOW TO MAKE YOUR OWN LAQUER BLANK DISCS
Post: # 2889Post cuttercollector
Thu Jun 05, 2008 8:06 pm
Not exactly on the SAME subject but lots of us have damaged styli.
Who could learn the lost art of styli re-sharpening? Can you re-sharpen a standard groove stylus to microgroove specifications. How much would that cost today? Is it possible to re-sharpen metal as well as sapphire?
BTW great ideas about the laquer discs. Someone needs to see what type of coating process Apollo uses. Isn't there a video of that? Also more investigation into flexible and hard plastic materials.
Perhaps we need a DIY materials "section" to the group.
blight
Re: HOW TO MAKE YOUR OWN LACQUER BLANK DISCS
Post: # 2890Post blight
Thu Jun 05, 2008 9:21 pm
hmm with the appropriate tools and some training it shouldn't be too hard to resharpen a stylus i think. i wonder if it's done with CNC machines nowadays.
feel free to send me some old stylii and i'll try my best ;)
blacknwhite
Post: # 2891Post blacknwhite
Thu Jun 05, 2008 9:57 pm
cuttercollector wrote:Not exactly on the SAME subject but lots of us have damaged styli.
Good point, cuttercollector...
Gemstone faceting, even cutting from raw stock: It's an art, but it's not black magic. The wikipedia article, alone, tells you the basics of how to facet gems & the equipment needed: Someone could just follow those leads and see how much it would cost to "get into the hobby": http://en.wikipedia.org/wiki/Gem_cutting Seems from initial glance, the person who takes this up would need to find out what kind of microscope, and "microscopic-level ruler" (?), gem cutters would need to measure their cuts and angles. Info for required facets, atleast as of 1952, can be found here: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140105314627 .
motorino
Post: # 2892Post motorino
Fri Jun 06, 2008 4:59 am
thank you very much!
you have done a good work compiling all that information
one thing.....castor oil its ricinous oil, its the same oil used for two strokes motors for competition or races, the motorcycles smells like heaven when use! i believe http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXS627 this is the best oil and have red colour....
kremesickill
Just ordered..
Post: # 2897Post kremesickill
Sat Jun 07, 2008 2:09 am
I just ordered the supplies you listed. I'm going to take a run at it.. Of course, it might be months before i get around to actually doing anything with it, but i'll let you guys know how it turns out.
blacknwhite
Re: Just ordered..
Post: # 2899Post blacknwhite
Sun Jun 08, 2008 10:13 pm
kremesickill wrote:I just ordered the supplies you listed. I'm going to take a run at it.. Of course, it might be months before i get around to actually doing anything with it, but i'll let you guys know how it turns out.
Thanks K., would love to hear how it goes if you find time. And anyone else. If enough people try to find the time, one of us actually WILL...
- Bob
flozki
Post: # 2900Post flozki
Mon Jun 09, 2008 8:55 am
hello bob
thanks for sharing all that information...
thanks to everybody doing tests.. it would be great if there are a few sources more for laquers.even if they never reach the apollo quality..
thinking of doing it for years..like you: many irons in the fire.
made a few tests already with nitrocelluloseacetate..but the trick with the castor oil... maybe the missing key.
one idea i wanted to follow was the way they laquer the audio-cds.. on a rotating spindle. and they coat it with a uv laquer.. no solvents. dry within a second .i dont know if there is laquer soft enough.....but some research should be done into this direction.
i also have some books about amateur cutting form around 1930. there, they mention some DIY laquers. but with regular (nitro) laquer. no castor oil. mostly coated cardboard.. and i have a few diy laquers from this time.
loated cardboard. sometimes you even see that they coated with a paintbrush..
so hope to see some new laquer brands on the scene hehe.
take care and dont smoke during coating...
flo
Post: # 2926Post Aussie0zborn
Thu Jun 12, 2008 8:40 am
What a great idea. Good luck in making your own lacquers - let us know how it goes!!
The only problem with the above instructions is the cutting of the alumium disc. If you cut the aluminium by hand you will probably not have a flat disc. For the purposes of testing the lacquer formulation why not use a glass disc that you can re-coat over and over again until you get the formulation right? Once you have the right lacquer formula, you can then go to an alumium supplier and get the blank aluminium discs made professionally. Or, you can get an old lacquer, place it in boiling water to take the lacquer coat off and you have a proper aluminium disc ready for coating.
The first method for coating the disc (the conveyor belt) is probably the best and this is how its done at Transco. From what I saw when I visted Transco (and what you see in the YouTube video) this is the accepted way of getting an even and consistent coat on the disc.
Every lacquer disc manufacturer developed their own formulation and there was even a manufacturer in Melbourne, Australia called "Regal" or "Royal" back in the 50s or 60s. I have seen these discs but dont have any. From the Apollo website, you will see that the exception of this rule is Audio Devices' lcensing of technology and formulae from Pyral, France for the making of lacquer disc. Audio Devices was eventualy sold to Capitol Records where the trade mark "Apollo" came into play, and then later sold to their alumium disc supplier, GC International who operate Apollo today.
If someone can make lacquer discs like Pyral, France did, the world would be a much better place. Good luck!!!
blacknwhite
Post: # 2931Post blacknwhite
Fri Jun 13, 2008 2:20 am
More info on making high quality blanks can be found in the AES book "Disk Recording Volume 1" - some sample pages:
Details on the book, if interested:
https://lathetrolls.com/viewtopic.php?t=796&mforum=lathetrolls
- Bob
blacknwhite
Post: # 4452Post blacknwhite
Thu Feb 12, 2009 2:33 pm
<bump>
Heard recent conversation/complaint about acetate/lacquer blank company monopolies...
Anyone had a chance yet to experiment yet with the above instructions making their own?
RVonse
Re: Just ordered..
Post: # 4474Post RVonse
Sun Feb 15, 2009 11:36 pm
I'm highly tempted to start ordering the laquer too as I have about 10 dubs that I ruined both sides on. I don't even have to worry about making the aluminum disc on those.
I was very suprised to learn that transco does not offer any kind of core discount for returned aluminum so I kept them around anyway. You would think Transco of all people would be able reuse the aluminum.
Re: Just ordered..
Post: # 4482Post markrob
Mon Feb 16, 2009 8:05 pm
I've been experimenting using Deft spray lacquer (I'm not sure if they still make this stuff, but I have some here). I intend to try coating a blank substrate at some point, but I've been focusing on re-using dead balnks that I have from tests and bad cuts. My first experiment was to try and re-flow the existing lacquer by dipping the blank into thinner. I let the lacquer soften and used a brush to smooth out the surface. This technique is used by some furniture re-finishers to avoid stripping and recoating. My first attempt, shows some promise, but I need to build some fixtures to hold the blank so that it can dry properly.
My next experiment was to simply shoot some new spray lacquer on top of the used blank. I roughed up the surface with 600 sandpaper. Then I sprayed several thin coats of the laquer to build up the surface (the Deft dries very quickly). This worked pretty well , but again I need some fixturing to get best results. If I get anywhere, I 'll post here.
Post: # 5101Post Aussie0zborn
Mon May 25, 2009 3:35 am
More discussion on making lacquer blanks on an engineering forum...
http://www.eng-tips.com/viewthread.cfm?qid=242715&page=1
blacknwhite
Post: # 5104Post blacknwhite
Mon May 25, 2009 12:01 pm
Aussie0zborn wrote:More discussion on making lacquer blanks on an engineering forum...
That was me. (recordman)
I finally decided to go ahead and experiment. Hadn't planned to announce it yet (don't know if it will be successful or not).
[edit] Hey Aussie0zborn, are you "vinylguru"?
- Bob
Post: # 5108Post Aussie0zborn
Mon May 25, 2009 7:55 pm
No Bob, nothing is succesful until you try it and then try it some more! Good luck with it.
No, Im not "vinylguru" in that forum. He is a fellow lathe troll and I'm sure he will make himself known.
Master Lacquers, Formulae etc
Post: # 5150Post mossboss
Wed May 27, 2009 9:11 am
Ok to all you wondefull people who want to make "acetates"
Here is a receipe that works It comes from a variety of sources over a number of years of scratching around The basic formula was used for "Instantaneous Record Blanks" Popular in the thirties and forties other modifications to the basic mix is a collection of bits and pieces
The different types of cellulose(s) is there so as to impart certain characteristics to the lacquers such as filming or cracking as well as shrinking Besides making them less liable to catch on fire Nitrocellulose is highly inflamable
The 2 different alcohols are there so as to stop the violent evaporation when they are drying out (slow them down)
Formula
33.3% of .5 second Cellulose nitrate (powder)
28.2% of ethyl Acetate (powder)
9.95% of Cellulose Triacetate (powder)
18% (of wetting alcohols)
10% of dibutyl phthalate(powder if liquid carrier solvent should be known)
.5% of black dye
.05% finest carbon black (13 millimicrons)
Note on the solvent:
Wetting alcohol should be made from 80% pure alcohol and 20% Methanol
Here we go:
So just to prevent the obvious question Where do you get all these materials from?
Here are a few tips
Kodak makes all kinds of Cellulose they should be able to point out to you some users of these material in your area where you can get smaller qty's or they may be able to sell you some Ask
Dibutyl phtalate and cellulose triacetate I think (don't quote me have to check it out ) that it is the raw material used in capsules for medication, the Triacetate and dibutyl phthalate is in them in roughly those proportions, if you are to buy some, empty of course, get the analysis with them It will tell you the ratio and than you can figure it out for there
Methanol should not be an issue Your local biodiesel guru or club should see you good with that, alcohol well It is a hard one but I am sure that you can figure it out "don't drink it while making the mix up it will result in failure" Methylated spirits is just that alcohol with Methanol, but find out the amount of Methanol in there and adjust accordingly Check it out first as different stuff is used in different countries to "denature" it (Governments are the same everywhere they want to take the fun out of everything)
Black dye, Ink is what is used there it should be available at any stationery store
Carbon black? well it is used to stop them "rising" in other words to stop them growing "horns" when they absorb moisture it is not really necessary unless you are in a very damp area and you are going to keep them for a long time it is a minute amount in the scheme of things
Some points to consider
Plates should be coated on both sides, when the coating dries out it will shrink and pull the coated side towards the centre in other words "dishing" them, that is why they are all coated both sides even though you only use one side to cut on It also gives you a fifty fifty change of getting one good side
Another major problem with lacquers is the fact that the solvents in the mix after it is applied to the medium, aluminum, thick paper, acrylic sheets, boil off real quick creating little vortices in the process which gives you a void or a hole
Therefore, they should not be allowed to dry in free air They should be put under slight pressure in the drying off stage to slow down solvent evaporation so as to stop that happening
Ok Some more tips
A vacuum cleaner with speed control should do the trick Of course you want to blow air in rather than suck, the filters in them work quite well So place newly coated plates in a large cabinet with some racking to take as many as you wish to coat
Get yourself some 3"-4" bit's of round timber and nail it on the selves (from underneath) so you can place your freshly coated plates there
Make sure that the shelves are perfectly level use some felt on the top of your bits of wood so they don't get scratched These lumps of timber should be high enough so they clear your hands when you place the plates on them
Once one side is touch dry which should not be that long coat the other side Inspect the previous coating for blemishes and coat them again if it is going to be an issue If it is out of the way than that is a usable plate
Further they should not have a hole in the center as the liquid will accumulate there leaving a raised area on the coated side, besides it runs out through the hole making a mess on the other side If you want to use older lacquers without removing the old coating scrape a litle of the lacquer away from the center and block the hole with a bit of 5 min Araldite sand it back smooth and flat with about 600 grit wet and dry paper finish it off with a 1000 grit wet and dry paper
Wash them clean with a bit of houshold detergent let them dry and coat them
You can boil them in water to get the the old laquer off completely or you can get them warm enough you can peel it off them as well, it is a trial and error job though to get the right temperature
Needless to say that you need a very clean area to do all this in, as small specks of dust as well as flying insects (they love the stuff) will certainly be an issue
Please take a look at Blackandwhite's previous post The methods he describes as an applicator should be fine Not the rotating one that will give you more trouble than necessary I am saying this as it is dificult to remove them from the jig besides you need very accurate thickness of the mix so as not to get runs on the plates
In so far as the warnings are concerned They very valid This is not for accident prone individuals and it is a a process that needs care and attention If you are not familiar with the dangers associated with the materials Make yourselve familiar with them first Read about them, as well as that, clearly understand the dangers associatted, proceed only when you have a clear understanding
Let's see what comes out of this than :!:
Re: Master Lacquers, Formulae etc
Post: # 5154Post Aussie0zborn
Wed May 27, 2009 9:25 am
Great info. So... who's going to be the first to try it???a
blacknwhite
Post: # 5173Post blacknwhite
Wed May 27, 2009 10:21 pm
THANK YOU SIR!
I'll surely have many questions soon...
- Bob
Questions
Post: # 5229Post mossboss
Sun May 31, 2009 9:22 am
blacknwhite wrote:THANK YOU SIR!
- Bob
You and about 1100 others This is how many views this thread had so far
Amazing :o
