scully LS-76 Nr. 666
emorritt
Post: # 20607Unread post emorritt
Fri Jul 27, 2012 4:38 pm
That's interesting; I didn't know he first copied the Lindstrom design (trolley turntable and stationary recorder). I would assume this would be similar to the machines the Sooy brothers used at Victor as well, at least early on. There is another photo somewhere of a lathe body similar to the one above with a weight drive attached and a mechanical recorder mounted in a saddle on the sled. Sort of a smaller, more primitive version of the larger modern Scully lathe. Will see if I can locate it.
Infrasonic Sound
Post: # 20668Unread post Infrasonic Sound
Tue Aug 07, 2012 2:35 pm
Just found out that mine is 651...How many were made?
Pete Lyman
Infrasonic Mastering
www.infrasonicsound.com
Studio:323.276.0477
W.B.
Post: # 22306Unread post W.B.
Tue Dec 25, 2012 5:53 pm
Serif wrote:When did Larry J. start designing and when did John J. stop?
John J. died in or about 1950, from what I've read, as the first automatic variable pitch / depth lathe was being developed and on the verge of being introduced; the models thereafter (such as the post-1955 model 601) were designed and its mechanics worked out under Larry J.'s aegis.
The company that developed and made the LS-76 was unrelated to the company that sold 501's, 601's and everywhere in-between as well as (in the case of the 501) before. The LS-76's manufacturer was the L.J. Scully Manufacturing Corp.; the prior company, Scully Recording Instruments Corp., was by then part of Dictaphone and its manufacturing base long moved to California (and also pretty much making only tape machines).
W.B.
Post: # 22307Unread post W.B.
Tue Dec 25, 2012 5:55 pm
It would appear, on the face of it, that at least 10 LS-76's were produced.
Re: scully LS-76 Nr. 666
Post: # 43623Unread post Aussie0zborn
Sun Aug 21, 2016 5:57 am
Where can you find the serial number on the LS-76?
Post: # 43886Unread post Aussie0zborn
Thu Sep 08, 2016 9:12 am
OK guys, don't rush to answer. Serial number found. It's #668.
EDIT : A better photo reveals that is actually Serial No. 662 so the mystery still remains.
jesusfwrl
Post: # 43913Unread post jesusfwrl
Fri Sep 09, 2016 2:07 pm
There is, however, a significant likelihood that Mr. Scully was indeed superstitious... what would he do in such case? No idea! Perhaps just skip the number to make sure he doesn't end up in the wrong place...
https://www.youtube.com/watch?v=JYGoougMHSQ
But then again, "it is better to regret something you have done, than to regret something you haven't done"
sameal
Re:
Post: # 44129Unread post sameal
Tue Sep 27, 2016 9:24 am
Nickou wrote:It seems tha the sculy wich was used in Bacelona by the EMI has been sold for the price of the metal ...
so we will never know if it was the 666 ... :(
NOOOOOOOOOOOOO!
WHYYYYYYYYYYYYYYY!
