leo gonzalez
strobe pattern rendered through LaTeX -
Post: # 25148Unread post leo gonzalez
Thu May 02, 2013 4:56 pm
publishing this one here, although it might belong to the playback section.
I was looking for a strobe pattern to print and came across this article http://www.jeffree.co.uk/pages/speedmeasurement.html.
by Tony Jeffree.
Really good read and found that Instead of using an image/photo editor the programmer renders his strobe patterns within LaTeX (http://en.wikipedia.org/wiki/LaTeX)
here's the code: http://www.texample.net/media/tikz/examples/TEX/rpm-disc.tex
The code is really simple and i did an edit to fit my application.
https://www.writelatex.com/166646llwdcn
this one is for whoever has a scully and a pitch98-13.
tweaking " \segments{10in}{4in}{16}\\};" and changing the last variable should render 8-16-32 sectors...
hope this one helps.
Flo Jvo, please verify if this one is OK !
Leo.
flozki
Re: strobe pattern rendered through LaTeX -
Post: # 25502Unread post flozki
Sat May 18, 2013 5:48 pm
thanks for the link.
i havent verified yet.
but i got a neumann 32 strobo pdf.
just print it out on self adhesive paper and voila. you got it.
pitch13 needs the 32 strobe. doesnt work with the 16.
on pitch98 you can jumper if its 16 or 32.
i will soon have the how to install pitch13 page ready there you will find it too.
http://www.floka.com/pitch13/pitch13_32strobe.pdf
for scullys you might scale it down a little bit.
