Kris D
Gotham Amp Help!!
Post: # 11990Unread post Kris D
Thu Jan 06, 2011 12:18 pm
Hi - I am hoping someone with a PB-150 with the equalizer section can help out here. I was putting the face back on the amplifier after cleaning and painting when I realized I failed to mark the position of the equalizer switch before removing the knob!!! Looking through the setup manual they reference the 78 eq as position 1 and the 33 eq as position 2. So starting at 78 you would turn clockwise from 78,33,45 and then to flat (with no movement in the 9:30-2:30 section). If someone can verify this for me on their unit I would really appreciate it.
Thanks - Kris
