Nickou
Neumann VG1 RIAA encoder
Post: # 5239Unread post Nickou
Mon Jun 01, 2009 1:14 pm
Hello ,
anyboby has the schematics of the neumann VG1 riaa encoder ???
many thanks
Yann
RIAA Schematics
Post: # 5480Unread post mossboss
Wed Jun 24, 2009 6:30 am
Hey Yann
Have schematics for the SAL 74B RIAA circuits namely Drawing no's SAB 74 G and SAB 74 E Let me know if any value to you If one thinks about it they should be the same
Not sure when the "famous" Neumann curve withan extra roll off was introduced It would not do anyone any harm as it is up around 50 KHZ going from memory
cohearent
Post: # 9222Unread post cohearent
Tue Jun 08, 2010 10:37 am
Hi Yann,
The RIAA encoding in the VG1 was done passively IN the power amp. There is a step up transformer, then the RIAA, then the power amp
Best,
Kev
Kevin Gray
motorino
Post: # 9224Unread post motorino
Tue Jun 08, 2010 10:45 am
Hi to all
I have VG66 schematics in .pdf....
Nickou
Post: # 9271Unread post Nickou
Fri Jun 11, 2010 7:38 am
Thanks Kevin for this info ,
I was imagining an esotheric design with tube active filter ..
The VG 66 schematics .. hmm
Marcos , do you have the copyright of this info ?
motorino
Post: # 9275Unread post motorino
Fri Jun 11, 2010 1:10 pm
shhhh :wink:
Marcos
Gerasim
Re: Neumann VG1 RIAA encoder
Post: # 28137Unread post Gerasim
Wed Dec 18, 2013 4:36 am
Hi. I repair Neumann VG 66. The schematics is very necessary. You can send to mail?
Gerasim
Post: # 28274Unread post Gerasim
Thu Jan 02, 2014 4:45 am
Hello. Maybe who has a scheme of the SI 66-R block (CIRCUIT BREAKER)? It from Neumann VG-66 rack. I can't deal with circuitry. It is a lot of rare microchips.
