flozki
passive riaa super simple
Post: # 4813Unread post flozki
Sat Apr 25, 2009 7:52 am
here the circuits i used for test on my dsikomat
it is a VIVANCO cd_to_phono convertor i found on the fleamarket.
i just changed one resistor.
now the attenuation is not that high. only 20db on 1 kHz.
ok the 20khz curve is 2dbs off or so.
but thats fine for simple heads like moving iron (prestos)
i used a grampian and it sounds quite good.
here the schematics:
and the simmulation:
this little box is very handy and will be now always ready for quick and dirty cutting test. hehe
f.
motorino
Post: # 4817Unread post motorino
Sat Apr 25, 2009 9:47 pm
Flo you are the best!
Very good contribution for me
In this world getting electronic designs is the most difficult, many thanks!
Simon
Post: # 6876Unread post Simon
Sat Dec 05, 2009 12:44 pm
What was the model number of the unit
VIVANCO PA111 ?
Happy to learn something new.
cuttercollector
Post: # 6883Unread post cuttercollector
Sun Dec 06, 2009 12:45 pm
Probably something like this -
http://www.mcmelectronics.com/product/MCM-CUSTOM-AUDIO-50-7240-/50-7240
not a pre-amp - the other way !
Simon
Post: # 6887Unread post Simon
Mon Dec 07, 2009 6:33 am
http://www.epanorama.net/circuits/phono.html
I found this on my travels...
piaptk
Post: # 7164Unread post piaptk
Mon Jan 04, 2010 1:10 am
On this thing, would you even need to switch out the resistor? It seems like this thing does exactly what you need it to do already?
Simon
Post: # 7170Unread post Simon
Mon Jan 04, 2010 6:24 am
Make model?
piaptk wrote:Image
piaptk
Post: # 7171Unread post piaptk
Mon Jan 04, 2010 9:06 am
cuttercollector wrote:Probably something like this -
oh, sorry.. It was this one....
Simon
Post: # 7176Unread post Simon
Mon Jan 04, 2010 4:07 pm
Sorry I did not see it in the other post
piaptk
Post: # 7182Unread post piaptk
Tue Jan 05, 2010 12:14 pm
Phono Input Attenuator
Device allows standard line level items to be played through magnetic phono inputs, commonly found on older home audio receivers and mixing consoles. CD/DVD/ MP3 players, tape decks, VCRs, computer sound cards and tuners may now be connected to unused phono inputs. In addition to providing the required signal attenuation, this unit provides passive equalization to compensate for the RIAA curve that is present on magnetic phono inputs.
So, does this thing need anything done to it?
piaptk
Post: # 7376Unread post piaptk
Fri Jan 15, 2010 11:35 am
I bought one of those Line level to Phono input attenuaters, and in the 3 min I spent on it, I couldn't get it to work at all... Signal goes in, but doesn't come out. But I was several beers deep in the evening and didn't spend a lot of time trying to figure out what the problem was. I do know that is significantly drops the input signal, and since my amp is already running at 7, Id rather find another way around this problem.
Would a 31 band eq be capable of approximating the riaa curve? I haven't looked at one up close so don't know if it has the correct frequencies.
piaptk
Post: # 7377Unread post piaptk
Fri Jan 15, 2010 12:21 pm
Nevermind, I think I found the answer in another thread... So, from what I'm reading elsewhere, it is just as effective, if not more so, to use an eq and experiement to find the appropriate equalization for your particular cutter head than it is to build or buy an riaa attenuator. Am I incorrect in this thinking? Sorry for all the nube questions, but I have limited electronics knowledge coupled with unbridaled enthusiam for learning this craft!
Simon
Post: # 7379Unread post Simon
Fri Jan 15, 2010 12:58 pm
piaptk
If you could put a link into your post that would be great
:wink:
piaptk
Post: # 7380Unread post piaptk
Fri Jan 15, 2010 5:11 pm
Simon wrote:piaptk
:wink:
Link to the other thread I was reading?
https://lathetrolls.com/viewtopic.php?t=410&start=0&postdays=0&postorder=asc&highlight=&mforum=
Post: # 7382Unread post markrob
Fri Jan 15, 2010 6:17 pm
The device has a large insertion loss so you may need a good deal up makeup gain to get any useful signal out. I think you would have a hard time creating the curve with a 1/3 octave graphic EQ given that you need about 40 db of total boost over the audio range (see Flo's plot earlier in this thread). Most EQ's only give 12-15 db of cut or boost. Better to use the EQ to compensate for any other errors in the signal chain.
Also note if you are using a Presto head, the device you have is wrong. The 500 hz turnover is built into the head providing if you have the correct series resisitor connected. In ths case, you could get away using the EQ, since you don't need as much total boost/cut.
piaptk
Post: # 7383Unread post piaptk
Fri Jan 15, 2010 6:50 pm
Ok, so are you saying that the curve is already accounted for in my Presto 1-C? Sorry, technical electronics is a foreign language to me...
Post: # 7403Unread post markrob
Sat Jan 16, 2010 3:54 pm
Partly. The high freq's still need a boost and there is a low freq boost below 50hz. That might not matter too much. IIRC, you need about 14 db of boost at 10Khz with the rise begining at 2125Hz. You should be able to come close to that with a 1/3 octave EQ. You have to add a resisitor in series with the head to get the low freq cut correct. The 1-C was out before the RIAA became standard. I think the value they originally used is for a 250Hz turnover, so youy may need to adjust it a bit to get hings correct. The value depends on the head impedance. Do you know what type your head is? If you do any computer based DAW work and can use VST plugins, I have one I created for the Presto. PM me with your email and I'll send it to you to try.
