Vinylrecorder + Garard Turntable @ Criminal Records
studiorp
Post: # 33123Unread post studiorp
Sat Jan 10, 2015 6:15 pm
Hi people, here a video of Criminal records that use a Garrard 301 for cutting with Souri overhead + cutting head.
Why a Garrard ? Is there someone that use here this tt ?
https://www.youtube.com/watch?v=D42isKW9MS8
Re: Vinylrecorder + Garard Turntable @ Criminal Records
Post: # 35241Unread post Aussie0zborn
Mon May 25, 2015 2:09 pm
Why Is he using a Garard turntable?
Because he wants a real turntable - one that has high torque, low rumble, etc etc and because he's got the money to buy a Garard. Unfortunately, not many people can afford more than a Technics SL1200. Garard is the way to go for overhead disc cutting set-ups if you can afford it.
studiorp
Post: # 35252Unread post studiorp
Tue May 26, 2015 3:50 am
Are you sure that the Garrard's torque is so high ?
Gus
Post: # 35258Unread post Gus
Tue May 26, 2015 11:50 am
studiorp wrote:Are you sure that the Garrard's torque is so high ?
Every good quality (broadcast) idler drive turntable have more torque than sl1200
the goal is to keep the rumble very low...
Post: # 35706Unread post Aussie0zborn
Thu Jun 25, 2015 1:38 am
Yes. I had a 401 with an SME tonearm but I gave it away. I had no idea they would be worth anything. The size and the weight of the motor tells you what you can expect. This is one hell of a turntable. Highly recommended for overheated cutting.
I had the pleasure of listening to a Japanese pressing cut with an SC99 head driven by valve amps. Can't remember which Tonearm was on the Garrard 301 turntable but the old and very classic Tannoy monitors were also driven by valve amps.
The last time I heard anything so good was playing an acetate in Cohearant's studio. I could have sworn we were listening to an LCR monitor set up but it was only L and R monitors - no centre speaker at all.
If you can afford a Garrard 301 or 401 turntable in your set-up.... Go for it!
