T560 Cutterhead Repair
Links to helpful record-lathe-oriented services (repair, equipment) and their websites.
PMST
Post: # 52943Unread post PMST
Wed Apr 17, 2019 8:00 am
I have a T560 cutter head and needs a repair as one of the tweeters sounds blown, possibly even both, but either way I assume both will need replacing.
I have been going through the diy repair approach but with limited skills in this area I'd rather send to someone, also I know how long Souri can take (if i get a reply) so wondered if there is anyone on here who can help? Ideally based in Europe.
Thanks
rubenr
Re: T560 Cutterhead Repair
Post: # 53261Unread post rubenr
Sat Jun 01, 2019 1:38 am
Maked?
Teddy
Post: # 57099Unread post Teddy
Sat Oct 31, 2020 8:28 am
Hey, I have the same problem. Burned one channel, need repair. And had enough of Souri's support, searching for someone else who can fix it properly. But most people don't want to get involved in what they don't understand. I'm afraid that this reverse engineering might take it to full makeover of cutterhead. And since its not working and maybe there will be no way out just to make our own. Maybe have any ideas what kind of electromagnets/drives are used? and how did your repair go? :)
jonty2k
Post: # 57102Unread post jonty2k
Sat Oct 31, 2020 9:47 am
You have a PM Teddy.
