pierre clement m2 cutting head
studiorp
Post: # 16134Unread post studiorp
Wed Aug 10, 2011 4:49 am
Hello to all, I have recently bought a Pierre Clement cutting head model M2 + a Poltz Freres lathe that I am restoring in these days.
My problem is the cutterhead, because the coil is good (in fact my tester sign about 22- 23 ohm ), but the original rubber damper ( probably silicone ) has gone.
Now the question is: where I must insert a little of silicone glue for rebuilding this damper ? Is possible utilize too other materials ?
Many thanks to all.
Cheers.
Raffaello.
studiorp
Post: # 16162Unread post studiorp
Sat Aug 13, 2011 4:29 am
Any help ?
Thanks.
studiorp
Post: # 16195Unread post studiorp
Tue Aug 16, 2011 10:56 am
About cutting styli ? Is there someone here that know which type I can mount ?
Thanks.
dubcutter89
Re: pierre clement m2 cutting head
Post: # 25013Unread post dubcutter89
Sat Apr 27, 2013 9:15 am
I'm not sure if there is any damping material in the pierre clement head. Some old cutters don't have damping material installed...
Does it look like this? (PIC FROM FLOKA.COM)
studiorp
Post: # 25018Unread post studiorp
Sat Apr 27, 2013 10:59 am
Yes, is the same head.
