Handcrank cutters? Do they exist?
Devoted to discussion of all-acoustic record-playing machines, such as Edison cylinder players, Victrolas, Brunswick Ultonas, and the like. When the Big Blackout happens, this will be the only audio evidence of our civilization (as it is).
Steve E.
Site Admin
Post: # 20237Unread post Steve E.
Wed Jun 27, 2012 2:57 am
That's gorgeous. I want it.
Post: # 20526Unread post tragwag
Sun Jul 22, 2012 10:43 pm
I've been reading about edison players a little bit, and it seems like the record function was a removable piece...
I don't have any to look at in person so any help would be great.
This looks like the cutter
emorritt
Post: # 20533Unread post emorritt
Mon Jul 23, 2012 10:17 am
Yes, that looks like the top of a recorder housing; underneath it should look like this:
Sorry I have an older digi cam which won't macro very well. If there is a stylus and it looks damaged, just heat up the holder and rotate with a pair of tweezers to a good spot. An Edison cutter is not much more than a sapphire rod with a small 'dent' ground in the end to make it sort of cup shaped.
The holder is easy to make out of a soda can if there isn't one, but if you don't have a stylus I'm not aware of anyone making reproductions. Complete units do come up on ebay very often though. Hope this helps.
Post: # 20645Unread post tragwag
Thu Aug 02, 2012 11:48 am
wow those pictures help a lot!
thanks.
the whole home recording thing for cylinders is really intriguing
