Relief graphic on blank side of vinyl record
SopranoC
Post: # 63165Unread post SopranoC
Tue Jul 25, 2023 9:06 am
Hello trollers, I have a question, do you know a supplier that can realize a stamper in order to have relief graphic on the blank side?
I would like to make a record like this instead classic etching.
Re: Relief graphic on blank vinyl side
Post: # 63166Unread post Aussie0zborn
Tue Jul 25, 2023 10:05 am
I would think you could get your design cut into a self adhesive vinyl sheet, stick it onto a lacquer disc and plate it. This assumes the silver spray will adhere to the vinyl sticker.
Anyone who makes stampers can do this if they don't mind some experimentation.
SopranoC
Re: Relief graphic on blank side of vinyl record
Post: # 63170Unread post SopranoC
Tue Jul 25, 2023 12:03 pm
Maybe UV ink could work too?
I thought to print the reverse image with UV plotter and then make the standard galvano process.
Anyone have done something like that?
