iRIAA preamplifier prototype
EposLab
Post: # 61031Unread post EposLab
Fri Jul 01, 2022 3:16 pm
It's been a long time I was thinking of building one of these.
I started with a single channel version as my lathe system is Monophonic.
This Prototype features:
- ALPS Input Volume Control
- Accurate iRIAA eq
- 40dB of total gain
- Low Pass Filter for 12kHz & 16kHz
- Fuse protection for the Cutterhead
- Adjustable VU meter for the Cutterhead
- Custom PCB , Mica caps & Dale resistors
Specifications:
- 2x18Vac external PSU
- Maximum Input signal : 2Vp-p @20Hz - 20kHz
- Maximum Output signal : 200mVp-p @20Hz , 2Vp-p @1kHz , 20Vp-p @20kHz
- 1U 19" rack mount
- Grey Wrinkle painted faceplate
I am currently testing it and looking for a way to print on faceplate and back. Sound performance is excellent and soon will make some measurements.
Any recommendation is welcome :-)
http:\\www.eposlab.gr
info@eposlab.gr
emidisc
Re: iRIAA preamplifier prototype
Post: # 61032Unread post emidisc
Sat Jul 02, 2022 1:46 pm
Looking good👍
I have some basic question
1. Presumably for mono you would require 1x iRIAA unit + 1 x PSU unit?
2. For Stereo 2 x iRIAA unit + 1 x PSU unit?
3. Have you got an Approx target Price?
Personally I would be interested in a Mono set-up that could possibly be upgraded to stereo later
Emidisc
EposLab
Post: # 61033Unread post EposLab
Sat Jul 02, 2022 4:13 pm
Looking good👍
Emidisc
Well there are lots of options there! This prototype I built for my needs cause (as of now) I use a single channel , Monophonic lathe system!
For 2 channel system (stereo) can be done by using 2x single channel iraa preamps (2x PSU) or make a stereo preamp in one case using a single PSU.
I am still testing it so this will need some time for it. One thing is for sure : the more I use it , the more I like it :-)
info@eposlab.gr
