FS: Vinyl Recorder T-560
OK, I've said I few times now that it might be for sale and now it is. I'd really prefer it to go to someone who doesn't already have one, so priority will be given to those potential buyers.
I'm going to assume you all know what a T-560 looks like and does, so I'll just list the non-standard aspects:
- first up, it has been repaired. There's a well-documented tale on here about the overhead mechanism breaking in the middle of the busiest run of cutting I've had in 8 years of doing this, which is one of the things that ultimately led to me not cutting anymore. Long story short, I had to machine parts myself and now it runs better than stock AND I know how to strip the overhead & reassemble it - I can show you how to do that.
- it's in a custom-built, professional flightcase and rack unit. Those alone cost £1000.
- the insane DJ mixer nonsense is long gone, so if you only know how to cut 'the Souri way', you'll have to get yourself a mixer and some superglue, or my recommendation - a mk i Mackie Big Knob, or run it from a DAW with an interface that has 2(or more) x stereo outs and a custom EQ curve. Again, I can show you how to do this.
- turntable is an SP-15. It has the re-engineered chip from Fidelis Analog and has been completely recapped and tuned. Solid, with no W&F up to 22g. If you're hell-bent on using a 12xx, I've got one, can swap out and I've got the steel platter for that. There's no tonearm for the 15 because I don't monitor while cutting.
- Vacuum is a Rietschle VTE-8. I know a few lucky people have run a standard shop vac without problems, but there are 10x more people who haven't. They're not made for continuous duty. The Rietschle is.
- I've put an ALPS pot in the Monitor Switcher so it can be used as a monitor controller.
- the heatlamps are long gone. I use a single infra red lamp.
That's about it. If I think of anything else, I'll add it later. Will not split any components. Buyer to collect. I can help you with set up and some training. Can supply blanks and everything you need to get started.
£6,000.
Will be more if it goes on Reverb, but thought I'd offer here first. Will cosider shipping at buyers time & expense.
PM only please.
£6,000.
PM only please.
Re: FS: Vinyl Recorder T-560
Sorry to hear you're packing it in, but at least I'm sure you'll sell it (them) on easily. All the best for whatever it is you're doing next!
- YOUYOU2021
Sent you an email, please contact me, luyindai@163.com
