FS/FT Rek-O-Kut Imperial 2
rootz
Post: # 59630Unread post rootz
Sun Oct 17, 2021 3:24 pm
I consider selling/trading my Imperial II lathe. The package contains: suitcase, deck, overhead, Audax RH5, power converter to 230V, some old styli, 33/45 adapter.
The Audax was re-magnetized and i wounded a new coil. Sadly i burned the coil last week, due to my new high power amp... But i can wind a new coil for the new owner.
I cutted one and a half years with it and now started to build my own lathe. I mainly cutted dubplates for our soundsystem.
I cleaned the lathe and repaired broken parts when i got the lathe about 2 years ago. It runs smooth and well.
As it has no 50/60Hz converter the speed has to be manually changed in the DAW. But never had problems with it.
I'm looking for a SP10 MK2/MK3 or anything else i could need for cutting (blanks, styli,...)
Lathe is currently based in southern germany.
Pictures upon request
Best,
Jo
jesusfwrl
Re: FS/FT Rek-O-Kut Imperial 2
Post: # 59714Unread post jesusfwrl
Mon Nov 08, 2021 10:47 am
This can be easily converted for 50 Hz operation without needing to use a converter:
https://agnewanalog.com/blog/rek-o-kut-model-v-repair-and-50-hz-conversion.html
rootz
Post: # 59822Unread post rootz
Wed Dec 01, 2021 2:08 pm
Thanks Jesus, that's a good info for the new owner.
---sold---
fleshbled805
Post: # 60203Unread post fleshbled805
Thu Feb 10, 2022 12:56 am
Inbox me a price... fleshbled696@gmail.com
rootz
Post: # 60204Unread post rootz
Thu Feb 10, 2022 2:29 am
Sorry, it's already sold
