WTB - Presto 8N platter and shaft
- EpicenterBryan
Hey guys,
I'm in need of a platter and shaft for a Presto 8N. I could make a 6N, 6D, 6E or 8D work as well.
I bought a package deal from a "picker", and the platter turned out not to be for this (not rim drive).
The motor, bracket and drive collar is also missing.
Anyone have something to sell?
Bryan
Bryan
- dubcutter89
Re: WTB - Presto 8N platter and shaft
https://www.ebay.com/itm/Presto-64-Transcription-Turntable-16-platter-assembly-parts-restore-from-1952/273867072527?hash=item3fc3bfe40f:g:KmYAAOSwVbhc7hKi
not sure if this is the thing you are searching for...
Lukas
Lukas
- EpicenterBryan
The platter I have is identical to that one. I'm thinking about going that way because that guy also have the shaft and bearing - and I also have a dual motor direct drive set up that also came from a Presto 64. So I could turn the 8N into an 8NG / 64 Frankenstein.dubcutter89 wrote:not sure if this is the thing you are searching for...
hi ..I can make you one ..but it will cost too much to do and send..easier to find a CNC machinest near to you to get one made..
my sexy 1967 Hamatu lathe can do this size..
and the bronze well bush too with loose or embeded steel ball
I can certainly supply a motor pulley and bracket. Here's some examples:
https://agnewanalog.com/blog/2019/06/14/presto-75a-50-hz-33-1-3-and-45-rpm-conversion/
https://agnewanalog.com/blog/2019/06/07/rek-o-kut-model-v-repair-and-50-hz-conversion/
Regarding the platter, making one would most likely be an expensive proposition. If you ever decide to go that way, you might prefer a proper vacuum platter. Otherwise, better hunt down a used one.
