Wanted: Presto 8D feed screws
audiocarver
Post: # 38266Unread post audiocarver
Mon Nov 02, 2015 4:38 pm
I'm looking for a feed screw for Presto 8D lathe. PM me if you may have one.
Thanks,
Andy
ROLANDJAYS
Re: Wanted: Presto 8D feed screws
Post: # 38267Unread post ROLANDJAYS
Mon Nov 02, 2015 5:49 pm
Can you post a picture of your lathe screw
audiocarver
Post: # 38268Unread post audiocarver
Mon Nov 02, 2015 6:43 pm
I wished I could, but there isn't one.
pandapolar
Post: # 38269Unread post pandapolar
Mon Nov 02, 2015 6:46 pm
im assuming they are different to 6N's ???
i have a few spare 6N feedscrews
audiocarver
Post: # 38274Unread post audiocarver
Mon Nov 02, 2015 10:45 pm
Apparently they are. I have an 8N here as well which is the same as 6N, but the 8D seem to be different.
I don't think the 8D screws were meant to be changed like on the 8N or 6N lathes as they had pulleys on the bottom to change the pitch by moving a belt. One end of the feed screw is a bearing. Where as on the 8N and 6N they have a Woodruff key on both ends.
Unfortunately, someone thought different on this lathe.....
ROLANDJAYS
Post: # 38277Unread post ROLANDJAYS
Tue Nov 03, 2015 12:52 am
I can , probably make you one if you could get a sketch or something.
rsimms3
Post: # 38282Unread post rsimms3
Tue Nov 03, 2015 8:24 am
I think the 8D and 8DG use the same feedscrew, try contacting EpicenterBryan about dimensions since he has a 8DG. There are a couple other folks that have one as well, but he's the first that comes to mind.
audiocarver
Post: # 38301Unread post audiocarver
Tue Nov 03, 2015 8:58 pm
Hi rsimms3, thanks! Hopefully he'll have info for me to get started with some dimensions. I've got a 8GV that this is for, but the 8D and 8DG used the same parts, just a few less features than 8GV. Unfortunately, this lathe was heavily modified, dual feed screws and 16 2/3 rpm adapter on the three speed transmission. I really don't need the dual feed screws, would love to have 16 2/3, but not at the cost of 33 1/3.
Hi Rolandjays, yes, I could. There are some other parts that I will need to have made on here as well. Working on a drawing for the variable pitch drive, but need the original feed screw pitch to calculate the rpm and pulley diameters for proper gear ratios to get the 76 to 500 lines per inch and all the steps in between.
Kris D
Post: # 38379Unread post Kris D
Thu Nov 05, 2015 11:47 pm
Hi, the 8D/DG/GV feedscrew is unique to these lathes. It is a square cut screw. The walls of the screw are at 90 degrees on both sides unlike typical Presto screws that use a saw tooth design. The 8D etc. use a halfnut instead of knife to engage the screw. In addition the screw has a moveable collar and gear assembly to select between outside in and inside out cutting. The odds of finding a spare are right up there with finding a NOS Scully still in its packing crate at the local goodwill for 19.99....possible but not likely!!
Check my PM and give me a call.
I may have a workaround solution for you.
Best regards,
Kris
