Are you in 230VAC land or 120VAC land? If you are in Europe the the two coils that form the Primary should be in series. If you are in the USA then the two coils that form the Primary should be in parallel.symatic wrote: if anyone actually knows what theyre on about and would care to enlighten me, that would be awesome.... if not i'll keep trying to suss it out.
If you have the Primary in series for 230VAC then Grey and Violet should be connected together and also bonded to chassis. If the Primary is in parallel then there is no connection to chassis on the primary.
On the secondary side Red and Orange should be tied together. If the Primary is in series this point should also be tied to chassis or 0V if different than chassis, like the Primary. If the Primary is in Parallel than this point should be tied to 0V/Chassis. 0V should not be left floating.
Don't forget to fuse one or both of the Primary leads. DO NOT ATTEMPT TO POWER IT UP WITHOUT A FUSE.
