VESTAX RECORD CUTTER ON EBAY
castillian500
Post: # 22574Unread post castillian500
Wed Jan 16, 2013 3:45 am
Are these any good for precise signal cutting ?
castillian500
Post: # 22576Unread post castillian500
Wed Jan 16, 2013 4:25 am
Not made anymore , right ? There for no spare parts , right ? Dub plates only ,right ? That would be OK but had to ask, Rare as hens teeth , right ?
castillian500
Post: # 22577Unread post castillian500
Wed Jan 16, 2013 4:39 am
Plenty of Vestax turntables around new and in production though.
castillian500
Post: # 22578Unread post castillian500
Wed Jan 16, 2013 4:46 am
I am answering many of my own questions here. It's discontinued. Here is the URL on the Vestax Web Site
http://www.vestax.com/v/products/detail.php?cate_id=183&parent_id=10
fraggle
Post: # 22580Unread post fraggle
Wed Jan 16, 2013 5:49 am
- its not in production anymore
- they dont make the original dubplates anymore (new ones are apparently different)
- its gonna be hard to find spare parts
- no original stylus anymore unless old stock
- sound from fuc... shit till you can listen to it :)
for 800 bucks worth to buy though :)
you could buy and modify it..
cheers
Diamond stylus
Post: # 22581Unread post Diamond stylus
Wed Jan 16, 2013 6:29 am
FYI, we produce for our clients stylus diamond for cutting pressed record vinyl or pvc! :wink:
www.diamond-cutting-stylus.com
fraggle
Post: # 22587Unread post fraggle
Wed Jan 16, 2013 1:12 pm
cool
castillian500
Re: VESTAX RECORD CUTTER ON EBAY
Post: # 22667Unread post castillian500
Sun Jan 20, 2013 12:10 am
thanks for the reference to a diamond stylus source. :)
vmspoland
Post: # 23376Unread post vmspoland
Fri Feb 15, 2013 6:14 am
the music in point is with digital , the knife of the cut must be from the sapphire , because the diamond is too hard and does spikes , the diamond is suitable only to DMM cuts in metal of copper , the sapphire is softer but has other mechanical proprieties only cuttable in soft materials
