WTB: Presto cutterhead (or similar)
aaron
Post: # 114Unread post aaron
Fri Oct 21, 2005 7:57 pm
I'm looking for a working, magnetic cutterhead in the lower range, ie Presto.
thanks.
-aaron
ameisevinyl
what you might need is...
Post: # 177Unread post ameisevinyl
Sun Dec 25, 2005 3:42 pm
Hey aaron,
what you need is an Grampian Type D cutter,
undestroyable...gives more or less good results, although
i now switched to the SC99 from vinylium...
you could the grampian from a guy called rob van dyke
he puts stuff like that on ebay from time to time...
i think grampian head will be around 1500$ or so
SC99 will be far better although its MC not MM,
its a rebuild of the neumann SX74 (this is the best...)
and works good with selfbuild electronics...
send an email to vinylium, they sell these heads at reasonable prices
check out http://www.vinylium.ch
hope that helps
