Vacuum bearing block for sale.
zdenek
Post: # 64657Unread post zdenek
Sat Apr 20, 2024 12:56 am
For sale is a bearing module, a bearing module, a self-lubricating vacuum one, for a lathe machine recording with a vacuum pressure of the plate from the bottom, there is an air suction hole from the bearing block and from the top of the shaft, the air sucked in passes through the sealing system and the air is discharged to the vacuum pump.
Dimensions
precision shaft diameter 20mm, shaft length including clamping sleeve 230mm, air inlet 10mm, threaded, housing body height 140mm x 100mm x 100mm.
The whole thing is hermetically sealed, super precise.
Price: $500 USA
zdenek
Re: Vacuum bearing block for sale.
Post: # 64659Unread post zdenek
Sat Apr 20, 2024 1:07 am
[in case of sale, I devote half of the funds to maintaining this website]
andybee
Post: # 64696Unread post andybee
Tue Apr 23, 2024 11:56 am
this looks like a pneumatic cylinder.... whats exactly inside?
zdenek
Post: # 64712Unread post zdenek
Wed Apr 24, 2024 2:07 pm
Hello .
My turner friends made this module for me.
I don't know what's inside this bearing block, I haven't disassembled it. The air goes through the shaft from the clamping sleeve side and flies out through the threaded hole [from the top of the housing] in the module housing and the air is sucked in by the vacuum pump. The device is filled with oil and sealed. The shaft rotates very easily and without play in the sliding bushes.
From the bottom, the shaft should be driven by a direct drive motor. If I have time, I will make a video of the principle of operation of this bearing block.
zdenek
Post: # 64766Unread post zdenek
Wed May 01, 2024 5:33 am
Unfortunately, the promotion ended today.
The current price for a vacuum block is $1,800 (including $500 to keep this website alive).
