Help with a Technics sl-j3
Stuff not covered by the other...Forii? whatever. General goofiness. (You should not post here unless you've been contributing elsewhere on this site.)
CountMoogle
Post: # 45917Unread post CountMoogle
Thu Feb 02, 2017 8:14 pm
So, I was surprised to find the Technics Direct Drive Automatic Turntable sl-j3 at a MajerThrift.
The needle was busted but the turntable and drive system worked just fine. I cleaned it out and replaced the needle with an aftermarket ATN-122EP.
The problem is, the bit of sound it gives out sounds terrible! Also only getting audio from one channel.
is there some initial setup that i missed?
Any input would be greatly appreciated.
