Scam/Estafa/Trapaça: Angulo, Tangential, Mejía, Vortex Vinyl Disc Recorder C-4, C-6
Distinct from the "Members Only" section about business disputes, this is a section for those special few sellers who have distinguished themselves through clearly intentional efforts to scam multiple customers. If you intend to start a thread here, please check it with Steve E. first.
VINYLKILLER
Re: Scam/Estafa/Trapaça: Angulo, Tangential, Mejía, Vortex Vinyl Disc Recorder C-4, C-6
Post: # 60696Unread post VINYLKILLER
Sun May 01, 2022 8:16 am
ALSO THIS TIME, LIKE THE OTHER TIMES, HE IS DELETING ALL THE ACCOUNTS, THEN CHANGING THE NAME AND STARTING AGAIN, BUT THIS TIME I SAVE ALL THE screenshots
IN A WAY TO PROVIDE THE POLICE WITH ALL THE DOCUMENTATION RELATING TO THE SCAMPER VORTEX (JONATHAN MEJINA)
OF COURSE I ALSO ALERTED FACEBOOK BY SUBMITTING A REQUEST TO MONITOR YOUR ACCOUNT. :evil: :evil: :evil:
VINYLKILLER
Post: # 60769Unread post VINYLKILLER
Wed May 11, 2022 11:17 am
MR. JONATHAN MEJINA
AN EXTREMELY SCAMPER JUDGE, YOU SENT ME THE REPLACEMENT FOR THE ENGINE, WHICH RUNS IN THE OPPOSITE OF NORMAL GEAR, IN PRACTICE OF YOUR MACHINE NOTHING WORKS. IT'S JUST A PIECE OF IRON.
MEGAMIKE
Post: # 60782Unread post MEGAMIKE
Sat May 14, 2022 1:01 pm
...good job....take him to task..
and a warning to everyone
don't buy anything unless you see the head cutting and the playback needle PLAYING IT BACK at the same time... :D
VINYLKILLER
Post: # 60893Unread post VINYLKILLER
Fri Jun 03, 2022 6:49 am
DEAR MR. JONATHAN MEJINA,
I HAVE HAD ANALYZED THE MACHINE BY DIFFERENT EXPERTS.
EVERYONE AGREES THAT IT'S JUST ONE BOX, IT WILL NEVER WORK !!!
BUT YOU DON'T BE ASHAMED OF WHAT YOU DO TO PEOPLE WHO WRONG LIKE ME HAVE TRUSTED YOU.
YOU ARE A MAN SHOWS EVERYONE THAT THE MACHINE WORKS, BUT MAYBE YOU ARE NOT THIS MAN BUT JUST A 4-ONLY SCAMPER.
CMQ. IF YOU THINK ABOUT IT, AND YOU MAKE THE MACHINE WORK AT 100/100, I COULD REHABILITATE YOU FOR EVERYONE.
VINYLKILLER
Post: # 60915Unread post VINYLKILLER
Wed Jun 08, 2022 10:44 am
Technical
Specification
English
Vinyl Disc Recorder
Model: Automatic C-6V3 – VORTEX
Phonograph Recorder
Cabezal de corte grabador 45/45 Estereofónico 300WRMS max
45/45 recorder cutter head stereo – 7hz-50Khz
300W-RMS m a x
Prensa de sujetcion de aguja de corte universal:
Accept Diamantes de corte des 3D Wester hasta NSH-2S
SX68/74 (320---340) series acceptable PRESTO
3D cut diamonds des wester - NSH- 2S Neumann SX68 / 74
Accept todo tipo de agujas de grabacion
ACCEPTABLE ALL KIDS OF RECORDING NEEDLES
Mecanismo lineal 36kg 16”
36kg linear mechanism 16”
MODULO FLOTADOR/FLOAT MODULE
Regulador de profundidad de corte
0 a 50gr.
Cutting depth regulator 0 to 50 gr
Sensor de presión/F 0/50gramos
para la medición digital de la
Pressure sensor for digital
measurement of the depth of cut
Memoria de calibration de peso
total de cabeza de corte
Calibration memory of cutting head
Pantalla LCD screen lcd
Tube de suctor vacio (aspirator)
Elevación y descenso de la cabeza automática
En dos velocidades
Lifting and lowering of automatic head (2 speed)
Panel/ control
Regulador de temperatura de diamante de corte
Temperature controller cut diamond
0-7 V 3A.
Protector de rele contra cortocircuitos de filamentos de aguja
Protection against short-circuits in needle filament
Led indicator
Display de temperatura 7
segmentos Temperatura display
7-segment
Modulador de distancia entre de surco
Groove whist modulador
Control de Elevación y descenso de la cabeza
automática
Control Lifting and lowering of automatic head
Control Dirección de vector izquierda
/derecha Dirección left / right vector
Modulador de distancia entre surcos automáticos
Acelerador por amplitud de onda
Accelerator by wave amplitude
Gráfico de curva de aceleración lineal
Linear accelerator curving graph
Vúmetro analógico de 7cm X 13cm
Analogue vumetro
Sistema de grabacion automatic
Automatic Recording System
Automatic programmable controller time and space: diskette boot
track 1 to 10 space / tiempo10sg between tracks, disc closure,
positioned head to start point, kick, to disk lifter head with enabler
fall
Pantalla LCD 24X4
Key board
Grabación 33rpm 22minutos-27minutos por lado
Grabación en 45rpm 15 minutos a 18 minutos por lado
Recording 33rpm 22minutos - 27minutos per side
Recording in 45rpm 15 minutes to 18 minutes per side
Accionador de separation /acceleration tangential
Regulator de separation / acceleration tangential
Accionador de cierre de espial / closing spirals
REMOTE SYNCHRONIZATION SYSTEM
– PLAY – STOP
FOR ANY REPRODUCTIVE EQUIPMENT
DISC DIMENSION SELECTOR -AUTOMATIC HEAD
POSITIONING 7” – 10” – 12” – 14”-16”
TURNTABLE 16” SOLID ALUMINUM PLATE 11 THICK
REVOLUTIONS
16RPM - 33RPM - 45RPM -78RPM
2RPM TO 78RPM
1500X AUTOMATIC MICROSCOPE
Peso total 50 kilos
Total weight 50 kilos
Color a elección gris/plata, negro brillante, blanco, rojo
Color gray / silver Election, bright black, white, red
Alimentación
110/220V. Power
supply 110 / 220V.
Construcción aluminio ACERO
inoxidable
Metal inox 100% Aluminum metal
Steel construcción 100 %
VINYLKILLER
Post: # 60916Unread post VINYLKILLER
Wed Jun 08, 2022 11:18 am
MACHINE SCAN
VINYLKILLER
Post: # 60917Unread post VINYLKILLER
Wed Jun 08, 2022 11:21 am
Technical
Specification
Spanish/English
Vinyl Disc Recorder
Phonograph Recorder
300W-RMS m a x
0 a 50gr.
En dos velocidades
Panel/ control
0-7 V 3A.
Led indicator
7-segment
automática
Analogue vumetro
fall
Pantalla LCD 24X4
Key board
– PLAY – STOP
REVOLUTIONS
2RPM TO 78RPM
Peso total 50 kilos
Alimentación
110/220V. Power
supply 110 / 220V.
inoxidable
MEGAMIKE
Post: # 60927Unread post MEGAMIKE
Fri Jun 10, 2022 2:34 am
looks like it will work to me
VINYLKILLER
Post: # 60932Unread post VINYLKILLER
Sat Jun 11, 2022 8:58 am
Hi !!!! I READ THAT SOMEONE HAS ONLY BOUGHT HIS HEAD, JUST TO TAKE A TEST.
I WOULD LIKE TO TRY IT ON THE MACHINE, IF IT WORKS I BUY WITH PLEASURE, SO THAT I CAN SELL THE COMPLETE MACHINE.
LET ME KNOW.
THANK YOU
soeffingodly
Post: # 61074Unread post soeffingodly
Wed Jul 06, 2022 9:15 am
LET ME KNOW.
THANK YOU
Last I knew his heads were paperweights/useless as well.
ilovedrums247
Post: # 61075Unread post ilovedrums247
Wed Jul 06, 2022 12:55 pm
famous last words
MEGAMIKE
Post: # 61096Unread post MEGAMIKE
Sat Jul 09, 2022 12:25 am
so if all the pictures above came to a customer from johnothon??
then ill say it again ..it looks like it will work to me...
ilovedrums247
Post: # 61100Unread post ilovedrums247
Sun Jul 10, 2022 1:25 am
Has anyone ever gotten one of these machines whole, AND gotten it to cut a disc of high fidelity music.
According to this thread, No.
But these pictures do make me ask some questions..
Where’s the cutter head?
Do all of those random needles work with the same head? (Are those diamonds in a zip lock baggie?)
Is that stylus cleaner label in German?
Where did he get that @myshank container?
How do you keep the (free floating?) turntable in one place?
How does any of it stay aligned while in use?
Why isn’t any of it shock mounted?
Why does the temperature gun have a soldering iron burn?
Why have a variable pitch turntable? Wouldn’t you only want 33,45,78?
Where the suction? (I see the pump…and it’s the cheapest one you can buy online)
Having looked at the inside on other pics, this thing looks nasty. Wired up like an old PC from 1995. A lot of cheap AliExpress audio boards for lights and show, cheap push buttons.
He did go a long way to make something the looks like a record lathe, gotta give him that… But something that works? Yet to be seen……
VINYLKILLER
Post: # 61104Unread post VINYLKILLER
Sun Jul 10, 2022 6:37 am
I BELIEVE YOU HAVE NOT FOLLOWED CAREFULLY !!!
THE CUTTING HEAD HAS NEVER GET TO ME ...
AND I HAVE NEVER BEEN ABLE TO USE THIS MACHINE.
ALL THE ACCESSORIES YOU SEE ARE MY OLD T560.
THE MACHINE TURNS ON AND MOVES, BUT I CANNOT DO ANYTHING WITHOUT THE CUTTING HEAD.
TALKING ONLY TO TALK AND CRITICATE IS NOT USING FOR ANYTHING, YOU MUST LIVE AND HAVE THE OBJECTS IN FRONT.
THIS DOES NOT REMOVE THAT MR. JONATHAN MEJINA IS A GREAT SCAMPER.
VINYLKILLER
Post: # 61105Unread post VINYLKILLER
Sun Jul 10, 2022 6:38 am
I WANT TO BUY A GOOD LATHE IN PERFECT CONDITION, IF YOU HAVE ONE I WOULD BE HAPPY TO KNOW MORE THANKS
MEGAMIKE
Post: # 61109Unread post MEGAMIKE
Mon Jul 11, 2022 3:12 am
ok I get it ...
try putting the VR head on it
does the overhead cradle move? left to right
can you stop plater when it moves with your hand or is it strong/powerful?
why you get this machine and not use VR
VINYLKILLER
Post: # 61143Unread post VINYLKILLER
Thu Jul 14, 2022 10:14 am
MIKE, YOU ARE VERY KIND, BUT I DON'T KNOW WHERE TO PUT YOUR HANDS AND WHAT TO DO, WITH THE T560 I WAS VERY GOOD NOW I DON'T KNOW WHERE TO START, PLEASE HELP ME GIVE ME SOME DIRECTIONS, I WILL BE THANK YOU.
MEGAMIKE
Post: # 61149Unread post MEGAMIKE
Fri Jul 15, 2022 11:20 pm
put VR head on this machine..
Iam not there to help..
send machine to someone that can help near where you live to mount head on vortex machine..not me Australia too far ..
if not then sell put in classified
go back to vinyl recorder its better machine :D
viniloramars
Post: # 61240Unread post viniloramars
Thu Aug 04, 2022 11:24 am
New machine from our beloved scammer!! Check out and feel free yo leave You comments !!
https://youtu.be/ilBzSAAdi5g
VINYLKILLER
Post: # 61384Unread post VINYLKILLER
Mon Aug 29, 2022 1:16 pm
All
today I start the denigrating camoagno against you, with complaints from all possible sides, sooner or later you will be annihilated. idiotic scammer of shit.
until I get your shack up and running I won't rest.
I will not let you sell a single amaccina in europe everyone must know what you are up to.
even if unintelligent, you tell everyone the same bullshit.
shit man !!!
thief!!!
shit man !!!
thief!!!
