Cutter head pins?
Kat
Cutter head pins?
Post: # 62148Unread post Kat
Sun Jan 15, 2023 9:45 pm
Hello! Wondering what exactly this pin and jack system is on my K8. I might be building an external box to feed audio into.
apoklis
Re: Cutter head pins?
Post: # 62149Unread post apoklis
Sun Jan 15, 2023 10:03 pm
They are old school banana plugs. The newer version has a wider diameter. On the k8 they are used for the input from the tonearm and the output to the cutter head.
apoklis
Post: # 62150Unread post apoklis
Sun Jan 15, 2023 10:08 pm
On the cutter head: take the two jacks off and use the two wires to a rca or 1/4 plug, then run that to the external amplifier you want to use . Did that help?
Post: # 62156Unread post markrob
Mon Jan 16, 2023 10:34 am
If you want to preserve that style jack and plug, here are the specs:
d3542_100.pdf
d5173_1_01.pdf
