NEWBIE STARTER GUIDE!
Angus McCarthy
Re: NEWBIE STARTER GUIDE!
Post: # 58331Unread post Angus McCarthy
Tue Apr 13, 2021 12:58 pm
Thank you, Mike!
Man, I wish this post was made 10 years ago, it would have saved me a lot of headaches and frustration over the years!
billythedev
Post: # 58907Unread post billythedev
Fri Jul 02, 2021 1:49 pm
Thank you for sharing all these informations with us!
crinch
Post: # 59770Unread post crinch
Wed Nov 17, 2021 9:26 pm
Thank you!!
Post: # 60073Unread post piaptk
Sat Jan 22, 2022 10:29 pm
Updated the main post for the first time in a few years.
tsalehpour
Post: # 60795Unread post tsalehpour
Mon May 16, 2022 11:41 am
Thanks for this!
fox___
Post: # 63009Unread post fox___
Fri Jun 09, 2023 9:20 pm
This is super helpful! Thank you for the breakdown!
Skwoz821
Post: # 63216Unread post Skwoz821
Mon Aug 07, 2023 2:42 pm
Might I inquire if Sapphire Embossing on PETG is a bad idea?
I’ve read that PETG is softer than Polycarbonate, wouldn’t the be beneficial for fidelity and stylus life?
Post: # 63217Unread post piaptk
Mon Aug 07, 2023 5:36 pm
It just doesn't sound good. Lots of surface noise and dull high end.
Skwoz821
Post: # 63218Unread post Skwoz821
Mon Aug 07, 2023 9:08 pm
Any thoughts on heating a sapphire embossing stylus?
Is it pointless for embossing?
Has there been any research on this?
Also, I believe you’re the person behind recordlatheparts.com?
If applicable, what temperature are those styli rated for?
Just bought a stylus from there, can’t wait to try it out.
Cheers!
Post: # 63220Unread post piaptk
Tue Aug 08, 2023 1:14 am
We don't heat the stylus for embossing, just heat the disc to around 105 degrees. Never really tried. I've always been told that you have to have suction pulling air past the stone if you are heating it and suction is the reason I hate doing anything but embossing. And we get pretty good results without it.
But, if you give it a go, let us know how it works!
And yes, I run RLP.
CutR
Post: # 63442Unread post CutR
Sun Oct 01, 2023 6:06 am
Is cutting not embossing polycarbonate with tungsten ok? the reason i ask is the stock gakken/PO-80 blanks are PETG and are supposed to be cut with the stock stylus what i amuse is tungsten. Although I'm not 100% sure it could be steel no?
Post: # 63457Unread post piaptk
Mon Oct 02, 2023 1:19 am
I don't use tungsten needles or really cut (other than the very occasional diamond stylus cut or lacquer dub), I have found that embossing cones on polycarbonate are the best bang for my buck and get me great results for the money, so I've stopped experimenting with all the other possible combinations (there are plenty of combo results documented in my Newbie Starter Guide above).
shinyskittles
Post: # 63673Unread post shinyskittles
Tue Nov 14, 2023 1:33 pm
piaptk wrote:
Fri Jun 07, 2019 12:28 pm
(PVC) Pressed Blank Records and PVC Discs Pressed blanks can be ordered through a pressing plant in large quantities and Soft PVC blank discs are available from RecordBlanks.com, but only seem to work with tungsten embossing needles. Blank pressed records, only work with diamond cutting needles, and are, in my experience, not worth messing with. These are both very hard on styli.
Heat up PVC slightly would that be an option?
I have 10 yellow blank pvc records ready to be cut
