I have a T560 from Souri.
I want to get rid of the mixer.
Whats the best alternative set ups?
Please any advise would be appreciated.
Thanks.
GKC.
T560
- trailerparkjesus
Re: T560
good call!!
I think a lot of people use the BigKnob by Mackie. I think the easiest way is to get a monitor controller with a queue send that is unaffected by the main monitor knob (basically splits the signal one for monitoring and one output unaffected). Needs to have 1-2 outs and 2 inputs (one for your source signal and one for record player playback). Split the signal out of the queue for your level meter. Good Luck!
Re: T560
Hi, this is the way I took to get rid of the mixer...
If that can help you https://www.lathetrolls.com/viewtopic.php?f=1&t=8147
Cheers, Iz
Cheers, Iz
