Few Questions : New Cutting Head Project
DoKo
Post: # 51868Unread post DoKo
Wed Dec 05, 2018 4:16 pm
Hey guys,
I have recently discovered the wonderful world of lathe cutting.
I wish to design full diy cutting lathe . I have a few newbie questions:
1. What material is the base spring for the torsion bar? which thickness usually is it?
2. What is the importance of the cones? which part should they be connect to (large or small diameter of the diaphragm). Which material is recommended? I assume they affect the sound.
3. Can I use arduino for transferring sound to the tweezers? what is recommended?
4.Can you recommend nice basic tweezers?
5. Can you recommend a decent stylus?
6.Will stepper motors will be ok for moving the head or they will make a lot of noise while recording?
Any other tips will be very welcome.
Thanks all ! :)
DoKo
Re: Few Questions : New Cutting Head Project
Post: # 51869Unread post DoKo
Thu Dec 06, 2018 1:31 am
Also, which program is recommanded for mastering? ( Starting, preferred free one).
soeffingodly
Post: # 51873Unread post soeffingodly
Fri Dec 07, 2018 8:59 am
Welcome! I'd suggest doing some searching and reading on the forums first. There are a bunch of posts floating around with all kinds of useful and bewildering/exciting information.
Specifically check out the Experimenters' & Innovators' forum. There are some good posts at the top for starters.
...and good luck with your project!
