Diamond cut records not that loud
nikc
Post: # 50582Unread post nikc
Tue Jun 12, 2018 4:04 am
Hello everyone
I have an MSS machine with MSS cutterhead. I have been cutting with a myshank diamond on myshank blanks. All is going well, apart from I notice the playback sound wasn't that loud compared to a 7 inch single from the 1980's. About 66% of the volume.
Perhaps this is normal and the best you can get from a 1959 cutter head?
If i turn the volume up anymore I think it might blow the head (though I have a fuse inline).
The impedance of the cutterhead is 4.7 ohms and my input audio signal is around 3-4 volts.
I was wondering if i need new magnets. I have bought some nichrome magnets, but they almost seem too powerful! But perhaps i should install them.
Any thoughts anyone?
Nik
Nik Clifford
Pearl Home Records
Jccc
Re: Diamond cut records not that loud
Post: # 50586Unread post Jccc
Tue Jun 12, 2018 7:53 pm
im sure you should be able to get louder cuts out of your head especially if you got a fuse inline protecting your cutting head.
For me I usually set my levels to the point where the fuse blows out and then replace it with a fresh one and back the volume down till the fuse does not blow.
From there I got a reference to where I should set my volume meter.
Thats how I adjust my levels and I get them sounding almost too loud to the point where the grooves collide and I have to turn it down a bit.
some people record differently but thats how I've been doing it.
nikc
Post: # 50588Unread post nikc
Wed Jun 13, 2018 3:45 am
Thanks I'll give it a go, and maybe increase the volume during the cut.
I was also thinking of replacing the magnets in the head too as they are old.
Nik
Nik Clifford
Pearl Home Records
nikc
Post: # 57605Unread post nikc
Sun Jan 24, 2021 10:16 am
Hello. I have cuts much louder now. By turning up the volume and using more heat!
Nik Clifford
Pearl Home Records
