new guy here a few questions
Gridlock
Re: new guy here a few questions
Post: # 44557Unread post Gridlock
Sun Oct 30, 2016 11:50 am
bad ass
fredbissnette
Post: # 44558Unread post fredbissnette
Sun Oct 30, 2016 1:46 pm
theres a video clip a few posts up with some audio
i will look at stffening the head up a bit more
im going to do some more tests but im def running into resonance issues
its a huge learning curve for me but im getting lots of gain and my grooves are nice and tight and im getting about 4 min
at 33 on a cdr
its not to bad
cheers
fredbissnette
Post: # 44561Unread post fredbissnette
Sun Oct 30, 2016 7:13 pm
heres a lil vid of me cutting and another of the cut
https://vid.me/U0P2
https://vid.me/2zQx
fredbissnette
Post: # 44589Unread post fredbissnette
Tue Nov 01, 2016 8:58 pm
ive found cutting vocals to be a an excercise is surgical eqing but its coming along
i cut everything out at 300 hz
everything above 8000
reverse riaa
scoop out 500 hz
scoop out 4000hz
this makes vocals very intelligible
im learning where the resonances are
fredbissnette
Post: # 44601Unread post fredbissnette
Thu Nov 03, 2016 4:40 am
ive figured out i have a lot of cutter head motor noise translating onto my cuts
im going to strip my machine down and install rubber washers everywhere i can to isolate the the noise a bit
its not a horrible noise but its something i can improve with simple mechanical mods
cheers
fredbissnette
Post: # 44708Unread post fredbissnette
Thu Nov 10, 2016 6:38 pm
i have rebuilt my lathe i aquired a nice solid idler drive turntable and im going to make a jig to slide the deck in under
my lathe so gone is the belt drive deck that did not give me solid speed control
ive also switched mediums for embossing i have found a solid plastic plate i can cut into 7'' blanks, after a few experiments i found that glueing a backer board of cardstock to the flimsy plate makes a nice record that wont warp easy on the lathe
i got really nice sonic results embossing on this new disc after noodling with this
ill post pics later on
cheers
fredbissnette
Post: # 44716Unread post fredbissnette
Fri Nov 11, 2016 11:03 am
fredbissnette
Post: # 44746Unread post fredbissnette
Sun Nov 13, 2016 9:27 am
some audio i recorded of a cut i made today
strait of the turntable into my interface
http://www.mediafire.com/file/j9dt490eahxsksu/mutant+jazz+from+lathe+cut.wav
cheers
Soulbear
Post: # 44761Unread post Soulbear
Sun Nov 13, 2016 3:41 pm
Hi Fred,
The security suite on my PC prevents me from accessing the uploads you've made (Don't ask me Why??). Any chance of sticking them up on YT?? If not, what's your assessment of the performance of the Dayton Exciters? Are you happy with the Levels they can Output??
Regards
:wink: :P :D Soulbear
fredbissnette
Post: # 44762Unread post fredbissnette
Sun Nov 13, 2016 3:53 pm
ill put it up on soundcloud
they have tremendous output capability and i think they work very well
i am now in the process of finding out what the resonant frequencys are
i have ran pink noise thru my head and recorded it and found out where the
faults are
Soulbear
Post: # 44764Unread post Soulbear
Sun Nov 13, 2016 4:06 pm
Hi Fred,
Thanks for that assessment, I got a listen of the SC Upload and gotta say I'm impressed, not that much "Noise" at all, on the Lead-in. And the music seemed to be comming thru loud and clear. Fantastic Job so far Fred.
Regards :wink: :P :D Soulbear
fredbissnette
Post: # 44765Unread post fredbissnette
Sun Nov 13, 2016 4:21 pm
its coming and so far im using no off the shelf parts
id like to try some actual purpose made needles as right now im using a sharpened piece of steel
ive recorded all kinds of music with my lathe and im getting good results with instrumentals
vocals are a pain but thats what im working on with finding the resonances, im using a parametric eq to forensicly zero in
on the problem areas of the audio
its a proccess thats for sure
im having fun
Soulbear
Post: # 44769Unread post Soulbear
Sun Nov 13, 2016 4:46 pm
Hi Fred,
You've made massive strides so far, and moved your project along very quickly indeed. I can't help but think of the improvements you could possibly enjoy, if you perhaps used more "Rigid" Materials in the Construction of the Cutterhead Frame. It looks like you may be using Stiff Cardboard?? If not Aluminium, perhaps you could even use some thick Perspex/Acrylic, the sheet is cheap enough, and you can make it into an Angle like this :- https://www.youtube.com/watch?v=rkpqfcg1W_o or here maybe :- https://www.youtube.com/watch?v=wVEf7PfuKxo Maybe you have an old or broken Acrylic Turntable Dust Cover you could possibly re-purpose?? Just a few thoughts eh?
fredbissnette
Post: # 44771Unread post fredbissnette
Sun Nov 13, 2016 4:59 pm
i have many dust covers thats a great idea
i think i may go with some kind of alloy tho or mdf
there are also options like a 3d printer they have a few of these around at public libraries
cheers and thanks
let me know how your head turns out with the drivers i really like them and they were super easy to work with
i think making a stiffer head and bolting the drivers in place would def be better
Soulbear
Post: # 44775Unread post Soulbear
Sun Nov 13, 2016 5:25 pm
Hi Fred,
Well if you've got some old Acrylic Dust Covers you're Halfway there already. If it's a little bit thin, it's really quite easy to laminate it, with some Cyanoacrylate (Super Glue Type) Adhesives, Double or even Triple Thickness would ensure the Cutterhead Frame's "Stiffness" so that you get the utmost, out of the Dayton Exciters. Now I can't wait to test my "Soul Sculptor" Cutterhead propperly. I only did some Totally Non-Scientific Tests of pressing a "Dummy" Stylus, Up to the Metal Chassis of my Gas Fire. I've gotta say the Reproduction of the Music was really Loud and Clear Te He!!
fredbissnette
Post: # 44778Unread post fredbissnette
Sun Nov 13, 2016 6:46 pm
i added a triangle brace to the front of the head im not sure why i did not do this from the get go but
it really made a difference the head seems way stiffer now
i will def be looking at head 2.0 soon tho
cheers
Soulbear
Post: # 44786Unread post Soulbear
Mon Nov 14, 2016 6:22 am
Hi Fred,
fredbissnette wrote:i added a triangle brace to the front of the head im not sure why i did not do this from the get go but
I thought that by making/using a "Stiffer" Cutterhead Frame that you might see an Improvement "Step Change" in your Cutterhead's Performance.
fredbissnette wrote:i will def be looking at head 2.0 soon tho
Keep us Posted with your results
fredbissnette
Post: # 44790Unread post fredbissnette
Mon Nov 14, 2016 10:49 am
after doing the pink noise process and creating a template for cutting and also stiffening the head i have noticed a drastic
improvement
heres the result
https://www.sendspace.com/file/86huen
fredbissnette
Post: # 44806Unread post fredbissnette
Tue Nov 15, 2016 6:46 pm
