new guy here a few questions
fredbissnette
Re: new guy here a few questions
Post: # 46185Unread post fredbissnette
Thu Feb 23, 2017 12:53 am
new lathe im building for the mccurdy decks im getting
i may build two of these as i have two decks coming
rsimms3
Post: # 46188Unread post rsimms3
Thu Feb 23, 2017 9:04 am
For a heat lamp, if your lamp pictured is for heat, I would recommend a clamp on architect style lamp. I've found them much easier to position and they can be found cheap.
fredbissnette
Post: # 46191Unread post fredbissnette
Thu Feb 23, 2017 10:01 am
mine has like a snake in it its pretty easy to move and wont move easy when knocked if that makes sense
also ive pretty much built this lathe with no money
rsimms3
Post: # 46192Unread post rsimms3
Thu Feb 23, 2017 10:10 am
Yes, those are rigid and good for placement but your socket is hanging free so you don't have the additional adjustment like a dedicated lamp. I find the lamp easier to quickly move out of the way since it pivots freely at the clamp.
fredbissnette
Post: # 46193Unread post fredbissnette
Thu Feb 23, 2017 10:26 am
i has a switch
fredbissnette
Post: # 46239Unread post fredbissnette
Sun Feb 26, 2017 6:25 pm
rsimms3
Post: # 46241Unread post rsimms3
Sun Feb 26, 2017 7:25 pm
Are you at risk for melting your cutterhead or warming it to the point of deforming it?
fredbissnette
Post: # 46247Unread post fredbissnette
Sun Feb 26, 2017 9:09 pm
no its fine
fredbissnette
Post: # 46248Unread post fredbissnette
Sun Feb 26, 2017 9:14 pm
Jccc
Post: # 46249Unread post Jccc
Sun Feb 26, 2017 11:26 pm
Thats a Awesome set up!
Good job constructing that.
Soulbear
Post: # 46253Unread post Soulbear
Mon Feb 27, 2017 5:19 am
Hi Fred,
I like your latest Lathe-Build very much, and I see you use the tried and tested "Finger Stalling the Platter Test" for checking the Platter Torque :-
http://lathetrolls.com/viewtopic.php?f=15&t=7024&p=46093&hilit=finger#p46093
The Books and Academic "Stuff" will only carry you so far, and as you've shown here, the rest is always learned best by touching, feeling, and doing. I wholeheartedly approve of the "Heuristic" Methodology Employed for this Test, rather than relying on some of the Manufacturers Figures/Numbers. I like this approach to "Measurement Problem Solving" and as my Old Gaffer (Boss) once said to me, when he asked me what the Value was of a measurement I'd taken. I replied it was "Near Enough" to which he replied "I want it Spot-On" I then said "It is Spot-On" to which he further replied "Well That's Near Enough" I think the "Finger Stalling the Platter Test" to be similarly "Near Enough" to be "Spot-On" Te He!!
I suppose your next "Challenge" will be to get rid of any "Rumble" Transfer into the Recordings, from your Platter "Idler" Wheel Set-Up. Norman Field, the "Lathe Guy" owner of this MSS Lathe, made a New Idler Wheel for this "Ancient" Lathe, and the "Tyre" on the Idler is simply a Nitrile Rubber "O" Ring which, judging by the YT Video he's posted, seems to Transfer Motor Drive to the Platter Rim very Smoothly Indeed.
Regards :wink: :P :D Soulbear
fredbissnette
Post: # 46254Unread post fredbissnette
Mon Feb 27, 2017 5:20 am
https://vid.me/FF1a
12'' is now stable
more news to come
i need a proper idler wheel for my deck but its on the way
fredbissnette
Post: # 46255Unread post fredbissnette
Mon Feb 27, 2017 5:22 am
hey soul bear
i did use an oring and a wood core but the bearing is what i need in a proper idler
i got a wheel coming soon
cheers
fredbissnette
Post: # 46361Unread post fredbissnette
Wed Mar 08, 2017 6:57 am
heres s cut i did yesterday with my new setup and i had made my own idler wheel to test the torque of my broadcast deck
this is a 12'' test
https://www.youtube.com/watch?v=KSLZ8Ae3CIQ&t=52s
the speed is stable but my silly home made idler wheel is a bit wonky
i should have my proper wheel coming in the mail today or tomorow
fredbissnette
Post: # 46363Unread post fredbissnette
Wed Mar 08, 2017 11:49 am
fredbissnette
Post: # 46373Unread post fredbissnette
Thu Mar 09, 2017 10:27 am
fredbissnette
Post: # 46388Unread post fredbissnette
Sat Mar 11, 2017 6:52 pm
this is a test cut of a song playing on a turntable running thru my processing and playing thru the cutter head
this is what a record sounds like reproduced in real time on a lathe(embossing)
https://www.youtube.com/watch?v=09qjXIqXu_8&feature=youtu.be
fredbissnette
Post: # 46415Unread post fredbissnette
Wed Mar 15, 2017 3:28 pm
i got my idler wheel and im happy to report i have warble free audio now
fredbissnette
Post: # 46493Unread post fredbissnette
Sun Mar 26, 2017 5:27 pm
