Antistatic spray
Foo
Antistatic spray
Post: # 41501Unread post Foo
Mon Mar 21, 2016 3:30 pm
What do you guys use for antistatic spray? I used to use Souri's but ran out. I've also tried the myshank spray but find it doesn't always work as well. Any alternatives?
The Shank
Re: Antistatic spray
Post: # 41502Unread post The Shank
Mon Mar 21, 2016 4:07 pm
Foo wrote:What do you guys use for antistatic spray? I used to use Souri's but ran out. I've also tried the myshank spray but find it doesn't always work as well. Any alternatives?
So, sometimes, it works, sometimes not?
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
mischmerz
Post: # 41504Unread post mischmerz
Mon Mar 21, 2016 10:03 pm
Actually - I am using PG (Propylene Glycol) and mix it 1:1 with Turtle Wax. Just one drop and my static is gone. But your mileage may very of course. PG has the nice added value that I can use it in my vapor e-cigarette as well. Without the turtle wax though ..
Michaela
mischmerz
Post: # 41505Unread post mischmerz
Mon Mar 21, 2016 10:08 pm
But .. since I have that nifty little blower (in the back) I hardly care anymore. Static? What static? Got it for 60 bucks on the Bay. Aerostat Ionizing Air Blower. Makes life a lot easier.
Gridlock
Post: # 41506Unread post Gridlock
Tue Mar 22, 2016 12:25 am
Grampian ftw
studiorp
Post: # 41507Unread post studiorp
Tue Mar 22, 2016 3:42 am
But which disk do you use ? Policarbonate or vinyl blank ?
I use wood spray with beeswax before cutting on makrolon.
drdub
Post: # 41508Unread post drdub
Tue Mar 22, 2016 6:26 am
how noisy is that Air Blower?
mex
satan spins vinyl
*** www.drdub.com ***
mischmerz
Post: # 41513Unread post mischmerz
Tue Mar 22, 2016 10:41 am
I am cutting Souri's plastic discs. Lot of static and I had a lot of problems in the beginning. The swarf thread was clinging so hard to the disc, that my suction couldn't get it removed. But with PG treatment and the blower I don't have any problems anymore. The blower itself is not really noisy. One can regulate the air flow from almost zero to medium breeze. It's just a fan - but you can smell the ionization.
Michaela
drdub
Post: # 41530Unread post drdub
Wed Mar 23, 2016 9:14 am
sounds good. thanks for the info !
mex
satan spins vinyl
ilovethelawrencearms
Post: # 41650Unread post ilovethelawrencearms
Mon Mar 28, 2016 3:14 pm
Anyone have any good brands for antistatic spray? Or should I just use turtle wax? Maybe both? What works best for everyone?
