Wiring a Diy cutterhead
apman
Post: # 59853Unread post apman
Fri Dec 10, 2021 6:26 pm
Hi I've researched AES papers and built a DIY stereo 45/45 cutterhead. Image below. No motion feedback hoping to use ableton or DSP.
Image link:
https://ibb.co/jDcKzB7
https://ibb.co/w7qw9ML
How do I wire up the transducers?
Do I plug the L from the mixer into channel A of the amp and R into channel B ?
Or do I run the amp in mono and invert polarity on one speaker? Need some help :)
Or is there a series parralell type circuit needed.
Any help appreciated
Re: Wiring a Diy cutterhead
Post: # 59856Unread post markrob
Sat Dec 11, 2021 10:05 pm
Just wire one of the two speakers with reverse polarity to your stereo amp and you are good to go. You can cut in stereo or mono with this setup depending on the signal you send from you mixer or DAW.
