Glad about my 1st release
EposLab
Post: # 54621Unread post EposLab
Tue Dec 10, 2019 8:43 am
Really very glad about my first official vinyl release!
After a contact with Thanos of Lost Bodies (GR) we agreed for a short lathe cut run of 20 copies of their 2008 album " The end of time"!
The original album consists of a 73min single track so there was a need for edit and remaster for my needs.
I ended up keeping the at 27min for a single sided disc.
My work was done on my Rek-O-Kut Master Pro lathe
(V & B5 @270LPI) and a Presto 1-D with Tungsten embossing stylus.
Embossing cone angle is 90 degrees and cutter head angle is 88 degrees.
After some tests i ended emboss with groove width a little less than 2mil as the background noise is more acceptable for me. Playback is fine as long the antiskating is set correctly. I could listen clear with no problems using my Grado Statement with tracking force at 1.5grams and antiskating at 1grams!
https://www.discogs.com/Lost-Bodies-The-End-Of-Time/release/14506179
http:\\www.eposlab.gr
info@eposlab.gr
discosdecorte
Re: Glad about my 1st release
Post: # 54622Unread post discosdecorte
Tue Dec 10, 2019 11:14 am
Congrats! :D
jesusfwrl
Post: # 54705Unread post jesusfwrl
Sat Dec 21, 2019 1:15 pm
Diving straight into the deep waters, with a 27 minute side as a first release!
Congratulations, the result looks great and that modified Presto 1-DA head sounds amazing! Keep up the good work!
By the way, post a picture of the laser etching on the other side, it looks really cool and will surely give ideas and inspiration to others!
EposLab
Post: # 54708Unread post EposLab
Sun Dec 22, 2019 9:41 am
Thank you trolls!
Jesus ,the laser engraving can be seen if you follow the discogs page ! There are pictures of the covers , labels etc.
One picture i would like to upload is a close-up of the grooves...
info@eposlab.gr
EposLab
Post: # 55176Unread post EposLab
Sat Feb 29, 2020 2:06 pm
That's my liking and as you already heard on my second release, it is an 9 minutes ambient track on a 7" Transparent disk @33,1/3 rpm!
(Really happy about my lathe's ability!)
info@eposlab.gr
symatic
Post: # 55204Unread post symatic
Thu Mar 05, 2020 5:25 am
nice music! congratulations on the cut and the release also
EposLab
Post: # 55661Unread post EposLab
Sat May 09, 2020 2:26 am
Well, after i made the Triangle stylus i was triggered and made a test cut of this (same track)!
Each sample is from the start of the track, both recorded @33rpm at the outer side of a 12" disk (both on black vinyl).
Sound level is not the same but very close. EQ is the same at High freq but on Triangle is abit lower at 530-600Hz.
Solid Tungsten Cone @ 0:00
Tungsten Triangle @ 1:10
Stylus_Cone_TRI_The end of time.mp3
*Please ignore the surface noise of the first part -
its because of countless times of playback :)
info@eposlab.gr
basplin
Post: # 55668Unread post basplin
Sun May 10, 2020 10:58 am
I ended up keeping the at 27min for a single side vinyl.
After some tests i ended emboss with groove width alittle less than 2mil as the background noise is more acceptable for me. Playback is fine as long the antiskating is seted correctly. I could listen clear with no problems using my Grado Statement with tracking force at 1.5grams and antiskating at 1grams!
Congrats!!! Super super cool stuff, sounds great!
Post: # 55671Unread post piaptk
Mon May 11, 2020 2:05 am
Sounds nice! Did you prep the disc with lighter fluid to remove the glue from the protective coating? You could also try one of our embossing sapphires from recordlatheparts.com. When dialed in you can get a VERY low noise floor and get rid of a lot of that crackle.
EposLab
Post: # 55675Unread post EposLab
Mon May 11, 2020 10:45 am
Yes , i have tried lot and various solutions but lighter fluid (zippo) is the best for embossing!
I have try your sapphire and have very good results o er the solid tungsten cone. If you like you can follow this link (https://www.lathetrolls.com/viewtopic.php?f=15&t=8676) and let me know your opinion!
info@eposlab.gr
EposLab
Post: # 57319Unread post EposLab
Thu Dec 10, 2020 2:37 am
Its been a year now and cannot be more happier with my official releases!!
info@eposlab.gr
