I've improved on the design of my Harting Connectors. The cuff that was printed to hold either a pin or a sleeve in place would get damaged by merely inserting the pin or sleeve. After enough uses, the pins or sleeve could be popped out of place. I'm now printing the connecters in two interlocking pieces. When screwed together via the guide pins and the cover, the two pieces of the connector firmly hold the pins or sleeves in place. You would have to break the connector to get the pins or sleeves to move out of place.
Deep Grooves Mastering - Harting 14 Pin Connector V2
