How does a mother record sounds?
tape
Post: # 43343Post tape
Tue Jul 19, 2016 3:30 pm
A bit weird question perhaps, but has anyone tried to play a mother (the negative used to make a record stamper)
I'm interested how it sounds...
thanks
Snakeheadfishlab
Re: How does a mother record sounds?
Post: # 43355Post Snakeheadfishlab
Fri Jul 22, 2016 3:47 pm
It takes a special player
Phinster
Post: # 43365Post Phinster
Sat Jul 23, 2016 7:21 am
Well, if you can even fit it on your turntable and get it to lie flat, it sounds virtually identical to the finished pressing.
In the old days, this was played back,checked and any ticks and pops were noted.
Being nickel, it will wear out your stylus pretty quickly, so styli for this purpose were re-sharpened.
Pip Pip! 8)
tape
Post: # 43385Post tape
Mon Jul 25, 2016 2:19 pm
I know that it can be played back using a special v spahed stylus
but how does it sound when played back with a normal stylus?
I imagine quite distorted...
Gridlock
Post: # 43390Post Gridlock
Mon Jul 25, 2016 8:04 pm
Too much variation in lpi with moderns records. But i am going to just tell you what you want to hear; it sounds like inside out aliens from uranus shooting lazer powered rock guitars into your ears and straight back out of uranus into the substrate of the 9th dimension oh also did i mention SLAYER played backwards sounds just like sweet baby james....ok back to work
Post: # 43412Post Aussie0zborn
Fri Jul 29, 2016 2:30 am
Your question is not clear.
A mother is a positive and can be played on a regular turntable if it fits. The stylus will wear out very fast. You should hear more pronounced highs. You should play it wet.
The father and the stamper are negatives. These require a special turntable with a special stylus.
I hope that clears up the difference for you.
tape
Post: # 43422Post tape
Sat Jul 30, 2016 2:21 pm
thanks - I see how it is unclear.
What I am interested in is how a negative record sounds played back with a normal stylus - if there is any resemblance to the original audio, or if the needle simply skips...
mischmerz
Post: # 43423Post mischmerz
Sat Jul 30, 2016 7:01 pm
tape wrote:thanks - I see how it is unclear.
There is no usable audio information in the valleys of a negative record, because all audio is in the ridges that will press it into the grooves of the record.
m.
tape
Post: # 43431Post tape
Sun Jul 31, 2016 1:35 am
I kind of had that idea:-)
I'm just curius if it's pure hiss, or there is something there...?
Snakeheadfishlab
Post: # 43433Post Snakeheadfishlab
Sun Jul 31, 2016 9:26 am
Actually,i have used glue to clean albums and when i peel the glue off i have a negative,i have played them and you get half of the signal and half of the signal of the next groove.very spooky sounding.
Gridlock
Post: # 43434Post Gridlock
Sun Jul 31, 2016 10:57 am
See: my previous post. Not just being a sillyhead
tape
Post: # 43436Post tape
Sun Jul 31, 2016 1:07 pm
interesting!
could you describe it more in detail?
Not sure what 'half the signal' should sound like?
Snakeheadfishlab
Post: # 43437Post Snakeheadfishlab
Sun Jul 31, 2016 2:44 pm
It seemed like you were getting the left channel of one side of the ridge and maybe the right channel on the other side but it would the next groove on the record,so the combined signal were two different things.makes me want to post a video of it.i will go to the lab today and post it here tonight
Jb
tape
Post: # 43444Post tape
Tue Aug 02, 2016 2:05 am
great!
looking forward to hear it.
Cant really wrap my brain around what is actually being played on a negative - I guess there should be silence in the 'grooves' but appreaantly not
Snakeheadfishlab
Post: # 43589Post Snakeheadfishlab
Wed Aug 17, 2016 9:24 pm
Sorry it took so long,work gets in the way sometimes.enjoy!https://vimeo.com/179269283
This is what a mother record sounds like
tape
Post: # 55820Post tape
Tue Jun 02, 2020 3:52 am
Sorry, we couldn’t find that page
tape
Post: # 64606Post tape
Tue Apr 16, 2024 7:28 am
still extremely curious to hear this - anybody?
would it sound like the LR difference signal?
kugelblitz
Post: # 64609Post kugelblitz
Tue Apr 16, 2024 3:22 pm
as far as negatives of records go: they sound surprisingly like the record themselves as long as you play them backwards. like a user mentioned above you can make a negative of a record with some woodglue and try for yourself.
here's a glue negative copy of a record, played forwards and backwards on regular turntable, that i happen to have just used in a radio-program about my woodglue records project.
forwards.mp3
backwards.mp3
weird but true: an inside-out groove sound still just sounds like the same music...
farmersplow
Post: # 64610Post farmersplow
Tue Apr 16, 2024 6:41 pm
forwards.mp3
backwards.mp3
Wow! Cool!
Great that someone took the trouble to test it!
Thank you!
tape
Post: # 64776Unread post tape
Thu May 02, 2024 6:58 am
thanks!
I just don't get why the negative would sound like everything played backwards....
