Hi there,
I found a motor at a local thrift/junk store. It seems to have two power inputs, and since it says Fairchild Controls Corperation, I thought it might belong to a record cutter (two inputs>>two speeds, ?)
Anyone know what this might be?
-Mike
Fairchild motor question (junkstore find)
Re: Fairchild motor question (junkstore find)
That's not a motor.
Clue is the 20kohm Lin on the back, it is a potentiometer, probably designed for a position servo controller or something.
1% specified linearity, 5% end to end resistance tolerance.
