Styro-Fail (Recycled Styrene Recording Blanks?)
Kat
Re: Styro-Fail (Recycled Styrene Recording Blanks?)
Post: # 60968Unread post Kat
Mon Jun 20, 2022 11:07 pm
Re-read the patent, looks like the T-shirt press would be good for the pre heat stage but not the final press. Looks like I’ll be doing some budgeting in the meantime to get everything together.
I could get custom CNC’d parts for the book mold but I’d like to see what improvisation could be done too.
nikc
Post: # 61534Unread post nikc
Fri Sep 30, 2022 12:39 pm
Hi.
This thread is amazing! Did you get anywhere with the polypropylene? Let us know if you have any new developments. I'd love to be able cut with recycled non pvc blanks.
Best wishes
Nik
Nik Clifford
Pearl Home Records
Kat
Post: # 61813Unread post Kat
Sun Nov 20, 2022 12:42 am
Hi.
Best wishes
Nik
Thank you so much! and thanks for your interest! I do have some updates to provide actually!
I picked up a Presto K8 that looks to be in good shape, the cutter sounds promising even without an amp yet. Good call. Kinda frustrating it took two recordios for me to figure out where cutting is really at but they look cool and I know how to re-cap now so I can’t really complain.
I’m also going to be trying out what markrob did with the Emory Cook process but cutting a few corners initially by borrowing a shop press and stealing my own PID control box from myself. That just leaves me with having to buy needles, some practice blanks, some heating elements, some laser cut molds, and an amp.
Planning to test both polypropylene and polystyrene but hopefully I don’t need to use PS cause it’s stinky and polypropylene sounds better anyway from the few tests I’ve done. Very excited to get this moving.
- Kat/Rai
nikc
Post: # 61903Unread post nikc
Wed Dec 07, 2022 3:16 am
Hi Kat,
Great, lets us know how the cuts go and good luck with your new Presto K8, and buying the rest of the gear. Good to know that you think polypropylene seems to be the best option
Best
Nik and Dom
Nik Clifford
Pearl Home Records
Kat
STYRO SUCCESS
Post: # 62038Unread post Kat
Tue Jan 03, 2023 1:27 am
It works it works it works it works. The Presto was all ready to go when the amp arrived, I just needed to throw on a disc. I started out with a couple CD records to test. Then I used a steel cutting needle with a recycled styrene record and was able to crank up the volume enough to escape the noise floor.
So they’re REAL, I just have to figure out how to make more discs and then I’m diving headfirst into production.
FullSizeRender.mov
farmersplow
Post: # 62044Unread post farmersplow
Tue Jan 03, 2023 4:29 pm
Fascinating! Congratulations on the success!
Kat
Post: # 63750Unread post Kat
Sun Nov 26, 2023 12:16 pm
I have made some progress on my Emory Cook inspired press for making my blank discs.
I have a steel plate with some angle brackets bolted on to make the shape of a 7” square. This will be sandwiched between a 7” pusher plate and two heated aluminum blocks and placed in a shop press.I just got done drilling and tapping holes for the bolts, PID controller circuits will be next.
I’m imagining the plastic needing a preheat before pressing or maybe just using smaller flakes so it doesn’t fly out of the mold.
farmersplow
Post: # 63751Unread post farmersplow
Sun Nov 26, 2023 2:54 pm
And the story continues!
Glad you've been working to develop this process further!
Good luck and keep showing us how it develops!
Thomas
