Laser Cut Record
- Oldskoolhousehead
Laser Cut Record
Hello all. I've been searching for the above mentioned subject for a couple of years, and I have found this project on instructables.com. My question is, has someone in the community ever tried that technique? If so, what was the result? Thank you for reading.
https://www.instructables.com/id/Laser-Cut-Record-version/
- circitfied
Re: Laser Cut Record
I had a project student try using the source code for an entire summer. They didn't have much success, I don't know whether this was down to the student or the source code.
From reading the work by Amanda Ghassaei on instructables on 3D printing and laser cutting and comparing it to the HD vinyl patent by Loibl you will see a distinct relationship. I hope you enjoy comparing the two. I would wonder if you presented the work by Ghassaei in court whether the Loibl patent would stand up.
- Oldskoolhousehead
Thanks for your input. If I remember correctly Ghassei's project predated HD Vinyl way before, and I don't know if the Austrian Company was "inspired" by Ghassei's work or not. However, vinyl production must go to the next level at some point (at least that's how I feel about it). The Apollo disaster proved that. Regarding the work of the Japanese guys, I want to give it a try, but an important part of the software combination has been missing and I couldn't get a feedback from those guys for months.
(Oldskoolhousehead, a vinyl junkie from Turkey)
- trailerparkjesus
yes we must move forward... there must be a format we can make with blank discs and lasers that don't crackle and pop or wear down with usage.....Oldskoolhousehead wrote: ↑Thu Aug 06, 2020 3:34 pmHowever, vinyl production must go to the next level at some point (at least that's how I feel about it). The Apollo disaster proved that.
