Anyone used Staticide?
- trailerparkjesus
Hey has anyone used Staticide before on the surface of PVC discs for cutting? Could be a good solution for the winter static season coming up!
https://www.amazon.com/ACL-Staticide-AntiStatic-Liquid-32/dp/B002WWNLVO?SubscriptionId=AKIAJD6FR5XRCBOC26MA&tag=ardorseo-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B002WWNLVO
- 2bitcomputer
Re: Anyone used Staticide?
Yep.
Been using it for years.
It definitely works.
I'd be interested in your/others' opinion of it...
+1
Works great, even when heavily diluted with deionised water.
- trailerparkjesus
handcut wrote:+1
Thanks for the input! Going to try!
- discosdecorte
Dear trolls,
Does anyone know where to get ACL Staticide in Europe?
Best regards,
Fer
Best regards,
Fer
π³πΈπ
π²πΎπ
π³π΄ π²πΎπ
π
π΄
- farmersplow
I have been using this for years.
https://cramolin-shop.de/antistatik-spraydose-200ml.html
Without this spray, the cutting thread usually remains in the groove and is difficult to remove. The "crackling" noise is also almost eliminated.
Do not smoke as flammable, do not inhale, causes eye irritation, use only in well ventilated areas. So not for wimps!
- discosdecorte
Thanks, mate!farmersplow wrote: βFri Apr 19, 2024 12:18 pmI have been using this for years.
Do you apply it while the disk is spinning and let it dry? Or does it need rubbing for drying?
Best regards,
Fer
π³πΈπ
π²πΎπ
π³π΄ π²πΎπ
π
π΄
- farmersplow
Hi Fer!discosdecorte wrote: βSat Apr 20, 2024 5:51 amDo you apply it while the disk is spinning and let it dry? Or does it need rubbing for drying?
Fer
A video says more than 1000 words:
So, I made a quick video for you:
1. dripping with wax
2. massage in the wax with a microfiber cloth
3. spray on antistatic
4. massage in with another microfiber cloth (or reverse side)
VIDEO: Greetings from Austria
Thomas
- discosdecorte
Thank you very much, very kind of you!
BR,
Fer
BR,
Fer
π³πΈπ
π²πΎπ
π³π΄ π²πΎπ
π
π΄
Do you have to clean the records afterwards? I use antistatic for clothes from the store target. Works like a charm but leaves a residue. Need to wash of in sink with degreaser and microfiber rag.
- discosdecorte
Hi!
I've finally tried with this spray and works great:
CRC 83009AF ANTISTATIK 100 200 ML
No need for rubbing or washing, it dries almost instantly
Best regards,
Fer
Best regards,
Fer
π³πΈπ
π²πΎπ
π³π΄ π²πΎπ
π
π΄
