Found X-26 Astatic Cutter Schematics & Possible Rebuild
HardlyHumanFX
Post: # 50893Unread post HardlyHumanFX
Wed Jul 25, 2018 1:48 pm
Hey Guys,
I found the original installation instructions and info on the x-26 astatic cutter head that uses salt crystal piezo. PDF files attached.
I also found an old, unmanaged website that details how to replace the salt crystal with a modern piezo element. I've never done it but the site claims it works well. Just food for thought. I'm afraid the site will not be up forever so I copied its contents. The original link is: http://www.angelfire.com/electronic2/radiosean/tv/Cartridge-rebuild.htm
I recently sent my cutter cartridge to West Tech Services in Kent, OH.
Jason
emorritt
Re: Found X-26 Astatic Cutter Schematics & Possible Rebuild
Post: # 50901Unread post emorritt
Thu Jul 26, 2018 8:26 am
The instructions are for rebuilding a crystal pickup, not a cutter. A crystal cutter is very different than a pickup. I've searched for years to find information on rebuilding a crystal cutter with no results. And if you open a dead one, all you'll find is white powder and some components that without seeing the real thing don't make much sense as to the operation. Piezo elements are designed to generate voltage when struck, twisted or otherwise stimulated, or to generate movement when power is applied. How the element is designed determines if the unit bends, twists or produces other movement. Check out www(dot)piezo(dot)com
