Dimi's Caruso Pre amp build
dimi751
Post: # 35352Unread post dimi751
Fri May 29, 2015 8:37 pm
Hi troll
I had fun making this even though it took me 9 months well I'm slow what can I say he he :D
It was fun to make and yes it is easy to make but you must reading all the Infos from vinylike website and tips from flozki and others on lathe trolls,and some electronics
Experience mine is not professional just beginner.
Please be carefull especially with the mains power, if you are not sure or confident hire Caruso build services here. Don't risk use professional.
http://www.lathetrolls.com/viewtopic.php?f=4&t=5275
I added vu meter at the front, this was last minute decision it was a pain in the arse to Dremal the square hole but with patience I managed to do it.
Here is a list of where I sourced the parts, most of you know already but I thought I make easier for other people who don't know where to find.parts where sourced in Australia.
Case 2u
http://www.altronics.com.au/p/h5032-2u-black-aluminium-front-panel-19-inch-rack-case/
Pre amp boards
http://vinylike.de/index.php/store/
Vu meter drive board
http://www.ebay.com.au/itm/TA7318P-PCB-VU-Meter-Driver-Circuit-Board-Stereo-Module-Upgraded-Edition-Hot-/261617494057
Components and transformers for Caruso pre ampli
http://Www.jaycar.com.au
And message to Flozki thankyou for designing a cool project I had fun with making this looking forward to more projects from you in the future :D
Sillitoe
Re: Dimi's Caruso Pre amp build
Post: # 35355Unread post Sillitoe
Fri May 29, 2015 9:08 pm
Very nice dimi!
What head are you planning on using?
dimi751
Post: # 35356Unread post dimi751
Fri May 29, 2015 10:39 pm
Hi Sillitoe thankyou
My next lathe trolls adventure will be making a diy head using off shelf speaker.
But first I needed to design my head, I will be doing diy 3d printer head in abs materials
I also have to figure out which speaker I'm using for the vibrations to the cutting stylus
Dimi
