Sillitoe Lathes
Sillitoe
Re: Sillitoe Lathes
Post: # 41750Unread post Sillitoe
Sat Apr 02, 2016 9:24 am
A huge thank you to George Nikoloudis of Soundtown over here in Perth Western Australia!
http://www.soundtown.com.au
This week I ordered the parts for his lathe, the first One! :D
His patronage enables this project to move from the research and development phase into production model reality.
Lathe options, specifications, pricing and website coming in the next couple of months.
Follow progress here and on the new Sillitoe Lathes Instagram account.
https://instagram.com/p/BDhrGKvEH7Q/
James
Skint
Re: Sillitoe Lathes
Post: # 41798Unread post Skint
Mon Apr 04, 2016 6:51 pm
Well done James - exciting times!
Sent from my LG-H815 using Tapatalk
Sillitoe
Re: Sillitoe Lathes
Post: # 41814Unread post Sillitoe
Tue Apr 05, 2016 8:42 am
Cheers Skint!
Lots of parts arriving now :lol:
Sillitoe
Re: Sillitoe Lathes
Post: # 41934Unread post Sillitoe
Mon Apr 11, 2016 12:25 am
Dynamic head with tweaked eq and some touches from a hf limiter (-2dB max).
1kHz tone at 7cm/sec.
Dopped chip in the middle of the track, hence the head lift... drop. :roll:
Great test track, I didn't cut the intro (out of phase stuff) because I haven't re-calibrated the depth magnet for my (much lighter) head just yet.
The cut doesn't do the song, mix or mastering justice but it shows that the head is ok. :D
I should be able to get the stereo and channel separation a fair bit wider in future builds.
Note- My crappy playback chain is heavy on the right channel :oops: I need to finish the boards that I'm building and get a nice tonearm/ cart mounted.
https://www.dropbox.com/s/oxaw8hco1fhixwv/my%20head.aif?dl=0
James
Re: Sillitoe Lathes
Post: # 41940Unread post tragwag
Mon Apr 11, 2016 2:26 pm
great progress! really looking forward to everything that comes in the future.
head looks great as well!
Sillitoe
Re: Sillitoe Lathes
Post: # 41946Unread post Sillitoe
Mon Apr 11, 2016 8:22 pm
Thank you Tragwag!!!
That last cut was on a Myshank black 7inch at 45rpm, lamp heat at about 40C on the disc.
The track is a remastered version from the Bad 2001 special edition release.
James
sakuszi
Re: Sillitoe Lathes
Post: # 41947Unread post sakuszi
Mon Apr 11, 2016 11:26 pm
Sillitoe, the sound is sensational! What do you use to cut the head? I did a little analysis of this signal, in general there is no background noise plate, below 30 Hz and above 13 kHz? Correlation phase is excellent! The recording sounds just as good as the original recording! Im very impressed ! Thanks ! :shock: :shock: 8)
Sillitoe
Re: Sillitoe Lathes
Post: # 41948Unread post Sillitoe
Mon Apr 11, 2016 11:45 pm
Cheers Sakuszi,
The cut is really not like the original, it lacks width and definition.
The playback system that I used to record the disk back into the digital domain is quite poor- the right channel is louder so the correlation is off centre.
Check out the original track on a scope, it is absolutely amazing! :shock:
I am quite pleased with the results so far. :D
James
sakuszi
Re: Sillitoe Lathes
Post: # 41949Unread post sakuszi
Tue Apr 12, 2016 12:26 am
a lot depends on the original signal. I still Stockfish record , because that is my point of reference is the sound different sounds, voice, music, musical instruments, the sound of a vinyl record, the work of the German machine.
I have some problems with the sound, it is 1.3 kHz - 35dB resonates at a fairly low noise, but it is audible. 8)
The bar is quite high, it is difficult to jump to 0 dB, above the head goes up in smoke coil drive 10 seconds 1.2 A + 3dB, and again the day job :roll: :D
Sillitoe
Re: Sillitoe Lathes
Post: # 41950Unread post Sillitoe
Tue Apr 12, 2016 12:44 am
Haha, that's why I named this head "Smokestack Lightning"... :twisted:
I need to build some with more precision, then run tests to determine their power handling.
Soon feedback also... :wink:
recordboy
Re: Sillitoe Lathes
Post: # 41951Unread post recordboy
Tue Apr 12, 2016 2:52 pm
Very exciting progress.
cheers
Cheers,
recordboy
Sillitoe
Re: Sillitoe Lathes
Post: # 41987Unread post Sillitoe
Thu Apr 14, 2016 12:55 pm
Yes, very exciting!!! Thanks Recordboy!
So I adjusted the antiskate :oops: playback is a little better now haha.
I just cut this with all the same signal chain settings and no mechanical adjustments to the Smokestack Lightning head.
(I'm also using 0.5amp fast fuses for protection)
The source file was an iTunes m4a...
Sounding good. :D
https://www.dropbox.com/s/axizxlc7vsbx0mf/Herecomethekings.aif?dl=0
James
Sillitoe
Re: Sillitoe Lathes
Post: # 41998Unread post Sillitoe
Fri Apr 15, 2016 2:46 am
Seems like the SP10MK2 likes the sound, steady grinning at 33.3rpm. :lol:
Sillitoe
Re: Sillitoe Lathes
Post: # 42088Unread post Sillitoe
Wed Apr 20, 2016 4:15 am
Thanks for the new boards Flo!!!
Smokestack Lightning cutterhead experiments continuing For a couple of different versions.
Also nearly finished the Wayne Kirkwood phono transfer system and elliptical eqs. Just waiting on some components.
Cheers Wayne!!!
James
Sillitoe
Re: Sillitoe Lathes
Post: # 42649Unread post Sillitoe
Mon May 23, 2016 7:22 pm
I've been losing my mind finishing my technical drawings over the last couple of weeks... Many many measurements! :shock:
I'll be able to post pricing once I get quotes on machining.
All the other parts for the first build have arrived.
Updates soon! :D
James
Sillitoe
Re: Sillitoe Lathes
Post: # 42727Unread post Sillitoe
Thu May 26, 2016 10:31 am
Digitally controlled analog Sillitoe Lathes logo.
Skint
Re: Sillitoe Lathes
Post: # 42733Unread post Skint
Thu May 26, 2016 12:23 pm
Love it! The logo marries the digital and analogue perfectly.
Sillitoe
Re: Sillitoe Lathes
Post: # 42735Unread post Sillitoe
Thu May 26, 2016 12:31 pm
Skint wrote:Love it! The logo marries the digital and analogue perfectly.
As does the lathe :wink:
Cheers Skint!
analoghifi
Re: Sillitoe Lathes
Post: # 42933Unread post analoghifi
Fri Jun 10, 2016 2:00 pm
James Great job brother, Ive been getting my updates here and I gotta say Im pretty much amped myself! Keep up the good work !
Sillitoe
Re: Sillitoe Lathes
Post: # 42939Unread post Sillitoe
Sat Jun 11, 2016 7:53 am
Cheers Kev!
Technical drawings are now with the machinist so I should have the parts in a week or two.
Then I'll put it all together and post some videos and options... :D
I've made 5 more heads and am currently working on a feedback version with complete analog chain.
The dynamic versions are performing well with FabFilter correction. :wink:
James
