How do I emboss
- alienmanstk
How do I emboss
Hello-
I've been cutting on old acetates, experimenting, and I do already know the difference between cutting and embossing, yet I do not know how to emboss... I know that this technique can save needles, especially if one is cutting on anything besides acetate... Is it just turning the needle around? Changing the needle angle? Length?
Thanks!!!
Sam
Thanks!!!
Sam
You can emboss on laserdiscs and CDs using a standard ruby needle that has been used a little while and has the tip rounded a little (not broken or chipped, just worn). You can also sharpen gramaphone needles and then tilt them to 45 degrees off the plastic, like Peter king does.
- Angus McCarthy
Are you tilting the head to 45 degrees? That is the only way it works, I think. Unfortunately, you can't tilt a 6n head that much.Angus McCarthy wrote:As to the use of gramophone needles...
I was under the impression that old steel needles were too sharp and had to be blunted and rounded to emboss properly. Have I been going about this the wrong way? It would explain why all I manage to do is rip a horrendous gash in the disc, rather than emboss.
- Angus McCarthy
Actually my homebrew uses an Astatic M-41-8 with the needle bent at 45 degrees. I'm wondering if there's a burr of some kind on the needle, or perhaps my weight may be off somehow.piaptk wrote:Are you tilting the head to 45 degrees? That is the only way it works, I think. Unfortunately, you can't tilt a 6n head that much.Angus McCarthy wrote:As to the use of gramophone needles...
PM me your address and I'll send you a few of the sharpened needles Peter King sent me. They are the same kind he uses. I can't use them.Angus McCarthy wrote:Actually my homebrew uses an Astatic M-41-8 with the needle bent at 45 degrees. I'm wondering if there's a burr of some kind on the needle, or perhaps my weight may be off somehow.piaptk wrote:Are you tilting the head to 45 degrees? That is the only way it works, I think. Unfortunately, you can't tilt a 6n head that much.Angus McCarthy wrote:As to the use of gramophone needles...
- Angus McCarthy
- alienmanstk
- Angus McCarthy
Click for full-size:
Peter King obviously started with a higher-grade needle than what I have on hand, but you can clearly see how truncated a cone it is compared to the raw gramophone needle. I suppose all I need now is a proper grind wheel to keep me in supply.
RELATED QUESTION:
I'm still working out the gearing for my transport. What would you say might be the upper-boundary for (non-automatic) pitch when embossing, considering the deformation that goes on? I was going to shoot for somewhere in the 150-180lpi range.
RELATED QUESTION:
- alienmanstk
- Angus McCarthy
If your W-G has a crystal cutting head or a magnetic one like my Astatic M-41-8 you will have to actually bend the tip of the needle itself, since there is no practical way to tip back an elongated cartridge like that. Be aware, steel needles will snap when bent cold so you will have to get them red hot to make the 45* bend.
I have an old pickup needle (maybe diamond?) that is rounded exactly as the peter king needle in the picture, but it's also bend by design and is perfect for embossing. However I only have one, and I have not been able to find out what these are calles in order to find more.
There is a picture here: http://totem.menneske.dk/batch_totem/ARCHIVE/MANUALS/BELL_RECORD_O_PHONE/Bell010.jpg
perhps a bit hard to see the bend or type of needle
- alienmanstk
Thanks for the picture as well....Angus McCarthy wrote:If your W-G has a crystal cutting head or a magnetic one like my Astatic M-41-8 you will have to actually bend the tip of the needle itself, since there is no practical way to tip back an elongated cartridge like that. Be aware, steel needles will snap when bent cold so you will have to get them red hot to make the 45* bend.
I'm still just unsure.... Should I bend the needle to that looking down at the recording arm, you can see the bent needle sticking out almost like a snakes tongue, or should it be bent inwards?
Thanks all for your response!
Sam
- Angus McCarthy
